Bottlehead Kits => Eros Phono => Topic started by: Ascari on May 06, 2023, 09:59:04 AM
Well I finished the Eros 2 today. This is my third Bottlehead Kit and it was probably the most rewarding. First off, I still have my first Eros (1) over ten years old. It currently needs some attention because only one channel working. I tried shot gunning a little bit and I am sure if I take my good old sweet time I will resurrect it. I also have a Beepre. To say that the Eros 2 is easier to build than the 1 is a true statement. When I finished my final voltage checks were all within a .1 to a .3 difference per side. Through out the whole build I made one small mistake and caught it before the reg board test. Other than that, all when according to the instructions. I am listening to an album as I write this. The best hint I could give anyone is to make sure you have a fine tip soldering iron and solder thin enough not to create bridges.
Congrats!
