Left channel hum - rack + Speedball
jj4001 · 827
Offline jj4001
on: February 15, 2024, 04:14:56 PM
After instal of the Speedball, I now have a low volume hum (110 -120 hz approx). Mostly in left channel. It is there regardless of volume position, inputs connected or not, tried different location, etc.
It is pretty low level but noticable between tracks and very quiet music passages.
I've done the chopstick test, reflowed a few joints, and tightened all screws/bolts. Any ideas for next things to check?  Odd to me that the volume control has no impact at all.
Thank you!!
Reply #1 on: February 15, 2024, 04:21:36 PM
What are the DC voltages on each terminal of each Speedball board?
Offline jj4001
Reply #2 on: February 16, 2024, 05:13:08 PM
Well I did something wrong for sure. When I went to test the voltages (black lead on 12U) I got a loud spark when I went to measure at 1A.
The fuse is not blown, but it won't power up now so I could have caused a big problem.
Reply #3 on: February 17, 2024, 06:55:27 AM
If you got a big spark, perhaps your meter wasn't set to read DC voltages?
If the amp won't power up, the fuse likely is blown and you'd want to pull it out and test it for continuity with your meter.
Offline jj4001
Reply #4 on: February 17, 2024, 01:26:16 PM
Ok - the fuse was good and amp powers up fine..  Whew...  Here are the voltages
OA 77
IA 180
BAB 0
IB 180
OB 72
OA 106
OB 106
G 0.1
B+ 180
Reply #5 on: February 17, 2024, 02:41:42 PM
Those are working voltages.
Offline jj4001
Reply #6 on: February 17, 2024, 03:45:29 PM
Good to hear. Any thoughts on what might be causing the low volume hum I described?
Reply #7 on: February 17, 2024, 04:17:02 PM
Do you get this noise with nothing plugged into the RCA jacks and the volume pot turned all the way down?
Is there a wifi router sitting next to the amp by chance?
Offline jj4001
Reply #8 on: February 17, 2024, 04:33:26 PM
Position of the volume control has no impact on the Hum. Rca's connected or not also has no impact. I've also moved it into a different room and still the same.
Reply #9 on: February 17, 2024, 04:57:51 PM
Offline jj4001
Reply #10 on: February 18, 2024, 07:18:37 AM
https://photos.app.goo.gl/JRRznj9BZFjryLPz8
Here's a link to 5 build
pics in my Google photos
Reply #11 on: February 18, 2024, 07:44:06 AM
Offline jj4001
Reply #12 on: February 18, 2024, 02:36:51 PM
Thanks, I will give this a try. Parts have been ordered.
Offline jj4001
Reply #13 on: February 23, 2024, 11:29:38 AM
I inserted the 2 opposing diodes today and removed the bare wire per the instructions. The left channel low hum is still there. No change in the level at all.
Reply #14 on: February 24, 2024, 06:45:37 AM
The next step in isolating is to pop off the front C4S board, then reinstall it 180 degrees from how it was installed previously.  You won't be able to screw it down in this orientation, but you should be able it leave it flipped up and get the wires reattached.  Once you've done this, observe if the noise has switched sides or stayed put.
