Bottlehead Kits => Stereomour II => Topic started by: Jamier on May 19, 2018, 09:39:22 AM
After researching the safety of running 4 ohm speakers from 8 ohm taps, I tried this with a Stereomour II for several hours yesterday. After 4 or 5 hours the PT seemed very, very warm.I realize that the amp must double the current under these conditions and so increased heat is to be expected, but is this safe enough to do? I really liked this pairing, but I'm not interested in melting down my beloved SII.The impedance curve for this speaker dips to 4 ohms at 45Hz, 200 Hz and remains slightly below 4 ohms beyond 4KHz.
Jamie
The amp won't know the difference.
Yes, that's normal.
The quiescent (average) current does not change.
No harm will come from doing this, but have you tried wiring the OT to 4 ohms?
PB,
Thanks for your response. I did wire the OTs for 4 ohms on a different SII that I also used with these speakers. The SII that is wired 8 ohm is one that I put film caps in the PS and getting to the OTs is a bit of an ordeal.
Jamie
