Bottlehead Kits > Mainline
Mainline voltage check failed [resolved]
(1/1)
Happy Ghost:
Hello All,
Can someone help me debug Breg voltage problem I am facing. So I passed all the resistance checks. Nothing remarkable except that terminals 19 and 30 read steady at 215.4 Kilo ohms and 208.8 kilo ohms. But after powering up first thing i noticed is that the LED's on the B-side of the C4S board connected to C-socket do not light up. All my voltages seems to be in spec (on a 120VAC connection) except for B-reg regulator board. These are the values I am reading.
+275VDC on Power Supply Board 274.7V
+6.3VDC on power supply board 57.7V
-6.3VDC on the power supply board 51.5V
IA on the A-side C4S board 274.3V
IA on the B side C4S Board 274.1V
Breg Regulator board: 216V (A-side), 156.3V (B-side)
-reg regulator board 0V both side
Kreg regulator board 9.88V and 11.34V
I have posted some build pics also.
Thanks in advance!
Paul Birkeland:
OA should not be wired to OB on the high current C4S board.
Happy Ghost:
--- Quote from: Paul Birkeland on September 16, 2023, 06:30:28 PM ---OA should not be wired to OB on the high current C4S board.
--- End quote ---
dang! this was such a blunder from my part .. careless :'(
thank you for pointing this straight away PB! after fixing the glitch, everything is in spec now.. it is running now and sounding very good.. thank you once again!
Paul Birkeland:
An easy fix is a good fix.
Navigation
[0] Message Index
Go to full version
