Bottlehead Kits => Mainline => Topic started by: dd076990 on August 16, 2017, 03:55:26 PM
A few months ago I had to pack my Mainline amp into storage since I was moving. Amp was sealed in a box + bag and the box didn't have any visible moisture or drop damage. I recently took it out to discover the amp giving off small amounts of distortion when it has signal, kinda like a guitar amp going into a slight crunch. Same sound on all music types. Dead silent with no signal with the fine and coarse controls at 0 (or any other position).
Things I already tried:
1) replaced the original tubes with new ones - no change
2) checked all the resistance measurements - passed all of them
3) tried moving the amp to a different power socket - no change
4) tried feeding it signal with various DACs and PCs - no change
5) tried different power & RCA cables - no change
6) re-checked the voltage and bias measurements - passed & output below
- +275vDC on PSB = 273.7v
+6.3vDC on the Power Supply Board = 6.29V
IA on the A side C4S Board = 273.1V
IA on the B side C4S Board =273V
Breg Regulator Board (both sides) = 219.8V & 221.5V
-reg Regulator Board (both sides) = 0.4mv & 0.3mv
Kreg Regulator Board (both sides) = 10.58V & 10.67V
T20 = 144.6V
T30 = 144.8V
7) Tried with variety of headphones & all possible balanced/unbalanced & impedance combinations - no change
Any ideas?
Pictures in case you need them (can't link directly) -> imgur.com/a/2hn1c
Does the distortion get worse as the music signal gets higher? Or is it more or less the same at any level?
The distortion gets worse as the signal gets louder. Very slight but still there on the low parts of a classical music piece for example, but glaringly obvious on the loud parts and anytime vocals are involved.
In the process of moving the amp and storing it, you've likely disturbed a solder joint that wasn't soldered or maybe was a cold joint to begin with.
If the distortion is on both channels, then I would be looking at all the black ground wires and inspecting all of those solder joints. A flaky joint will allow the DC voltages to all look right but will do strange things to signal current.
Just re-soldered pretty much every ground connection I could get access to. Seems to have fixed the distortion :) Thank you both for the help.
