Bottlehead Kits => Crack => Topic started by: Souter on August 24, 2019, 08:07:52 AM
Hi,
I've just completed my crack and all checks checked out as okay.
I then turned the amp on for a while and the tubes glowed and everything was looking good. I was getting very excited to hear how it sounds!
I then pluged my phono cable into the crack and went to place the other end into my headphones (Fostex t50rps).
A big spark shot out from the cable to the headphone!
I then decided to use one of the kids headphones for further testing!!!
I plugged a pair in and then listened, the audio was very distorted. As I pulled the phono cable out of the Crack a huge pop came out from the headphones and a spark emitted from the phono jack.
Is there anybody out there who could give any advice on this? I'm a bit gutted!
john.
Can you post your voltages and some build photos?
No Problem! Thanks for your reply.
Terminal Voltage
01 83.1
02 178.3
03 0
04 178
05 85.6
06 0
07 108.8
08 0
09 111.6
10 0
Terminal Resistance
01 *
02 *
03 0
04 *
05 *
06 0
07 2.96
08 0
09 2.96
10 0
12 0
13 *
14 0
20 0
22 0
B3 2.96
B6 2.96
RCA Jacks
Center Pin Black-90.5 / Red-91.9
Ground tab 00.2
I've also attached some pictures. Hope they are clear enough.
More Pics
More pics!
And another...
A5 looks to not be soldered.
The junction of the black wires on the headphone jack does not look to be well soldered (and would definitely cause the problem you observed).
10L needs more solder (and heat).
The #8 nuts need to be installed so the power transformer doesn't fall out.
Thanks paul, very much appreciated.
I'll take a look at your points in the morning.
Can't believe i forgot to put the nuts in!!
Will not be easy to do now though.
Paul, you are a total genius.
My creation has come to life.
No sparks flying and no distortion!
Thanks so much!
Good to hear!
