Bottlehead Kits => Stereomour II => Topic started by: DPetrini on July 08, 2023, 09:29:46 PM
Hi all, can the stereomour II use all types of 2a3 like RCA grey or black plates ?Just to be sure before try.thanxs
Yes.
Should be mentioned that early 1935-1936 "monoplate" 2A3 can be used in Stereomour and I wouldn't recommend using them in a stock SII. I wanted I'd recommend dropping the B+ voltage/limit the cathode dissipation and use a slow heater start up for longevity (maybe with the DC heater upgrade from Bottlehead?).
Thanxs, which tubes i can use in stereomour II without modify It , that sounds Better than psvane 2a3c ?
Try a pair of RCA bi-plates.
