Bottlehead Kits
Kaiju Stereo 300B amp
driver testing
driver testing
joralieu
518
1 Member and 1 Guest are viewing this topic.
joralieu
Full Member
driver testing
April 19, 2024, 12:46:58 PM
Driver testing I have 513 on 1A and 152 on OA also the LEDs on the B side are both out. It's the same for the A and D socket. Where do I look first.
Paul Birkeland
Global Moderator
Hero Member
Re: driver testing
Reply #1 on:
April 19, 2024, 02:38:47 PM
I would post some photos of your build so far. The 152V at OA could be related to the zener diode installation on the 5 lug terminal strips behind the 9 pin sockets, but I would bet on a missing jumper or a jumper going somewhere it shouldn't be on the PC board itself.
joralieu
Full Member
Re: driver testing
Reply #2 on:
April 20, 2024, 04:21:25 AM
Here are some photos
Paul Birkeland
Global Moderator
Hero Member
Re: driver testing
Reply #3 on:
April 20, 2024, 05:41:14 AM
It would likely be best to remove one of the boards, flip it over, and show a picture of the bottom as well.
joralieu
Full Member
Re: driver testing
Reply #4 on:
April 20, 2024, 03:06:25 PM
Another thought, I had my LM431A's in backwards. I desolderd them and turned them. Could that be the problem?
joralieu
Full Member
Re: driver testing
Reply #5 on:
April 20, 2024, 07:05:24 PM
Also had the JC29 backwards, had desolder and resolder them. Wonder if I may have damaged something in the process
Paul Birkeland
Global Moderator
Hero Member
Re: driver testing
Reply #6 on:
April 21, 2024, 05:42:08 AM
Did you swap the PN2907 with the 431, or did you install them all backwards? If you put them in backwards and powered up the amp, then you will need to replace all of those parts.
joralieu
Full Member
Re: driver testing
Reply #7 on:
April 21, 2024, 06:58:11 AM
They were all in the right place but I had the flat sides facing the wrong way. I corrected that before It was powered up.
Paul Birkeland
Global Moderator
Hero Member
Re: driver testing
Reply #8 on:
April 21, 2024, 10:18:19 AM
What are you Kreg voltages?
Even if not powered up, reworking these boards can be tough. Still, you have the exact same problem on both boards, so the same error is likely present on both sides.
joralieu
Full Member
Re: driver testing
Reply #9 on:
April 21, 2024, 02:24:37 PM
Socket A Socket D
Kreg A 4.1. Kreg A .06
Kreg B 1.8. Kreg B 1.8
Paul Birkeland
Global Moderator
Hero Member
Re: driver testing
Reply #10 on:
April 21, 2024, 03:12:39 PM
Both B side Kreg voltage indicate saturation, which would make me very, very interested in seeing the bottom of each C4S PC board. I would wonder if there are solder bridges present between pins on some of the transistors that got swapped around.
joralieu
Full Member
Re: driver testing
Reply #11 on:
April 22, 2024, 04:47:44 PM
Here is the bottom side.
Paul Birkeland
Global Moderator
Hero Member
Re: driver testing
Reply #12 on:
April 23, 2024, 04:31:34 AM
Could you double check that you have the 2.49K and 249K resistors in the correct places.
joralieu
Full Member
Re: driver testing
Reply #13 on:
April 23, 2024, 11:17:04 AM
That's It, those are in the wrong places. Would powering that way damage anything?
Paul Birkeland
Global Moderator
Hero Member
Re: driver testing
Reply #14 on:
April 23, 2024, 02:45:33 PM
It's quite possible that the 431 regulators may need to be replaced on that side of the board, but you can power it up and see.
Bottlehead Kits
driver testing
