Bottlehead Kits
Legacy Kit Products
Paramount
Ecc81 red plating. [resolved]
Rob Capizzi
951
Rob Capizzi
Full Member
February 09, 2024, 02:36:57 PM
Hey what's going on BH Friends? okay I recently purchased a pair
of Telefunken ECC 81 they've been working fine, they still work but
one I noticed is red plating on the plate that's on pin 9 side. Imoved
the red plating tube to the second amp and it did not follow so it
seems like the amp is red plating the tube What could be possibly
causing this? Thank you,
Last Edit: February 21, 2024, 02:34:52 PM by Paul Birkeland
Paul Birkeland
Global Moderator
Hero Member
Re: Ecc81 red plating.
Reply #1 on:
February 09, 2024, 03:07:44 PM
Can you post your voltages? Mostly you would want the I and O terminals on the A and B side of each board, as well as the Kreg pad on the half of the board that's populated.
Rob Capizzi
Full Member
Reply #2 on:
February 09, 2024, 03:21:21 PM
Thanks, Paul. Ok i seenthe I and O i will measure. What is the kreg. Would you specify for me please? I'm assuming it's marked k?
Last Edit: February 09, 2024, 03:23:49 PM by Rob Capizzi
Paul Birkeland
Global Moderator
Hero Member
Reply #3 on:
February 09, 2024, 03:23:06 PM
Can you send a picture of the version you have? There were a few different ones...
Also if just this tube red plates, but no other 12AT7 tubes red plate, then just don't use this tube as it may have an issue.
Rob Capizzi
Full Member
Reply #4 on:
February 09, 2024, 03:26:37 PM
I moved the red plating tube to amp 2 and it didn't redplate anymore. The tube tht ws in amp 2 that didn't red plate, red plated in amp 1
Rob Capizzi
Full Member
Reply #5 on:
February 09, 2024, 03:35:44 PM
The board pic
Rob Capizzi
Full Member
Reply #6 on:
February 09, 2024, 03:49:09 PM
Right side
456 I
385 O
Left
385 I
227 O
1.95 K
Terminal
16-455
17- 1.8
19- 224
20- 1.7
Paul Birkeland
Global Moderator
Hero Member
Reply #7 on:
February 09, 2024, 03:55:06 PM
I would replace the MJE5731A and 2N2907 transistor on the B side and the 431 regulator, and that will likely pull things back into proper operation.
Rob Capizzi
Full Member
Reply #8 on:
February 09, 2024, 04:03:12 PM
I have done them but not the lm431 because I did it on the other amp.
9 pin readings-
1.223v
2-0
3-2.5
4-3.1
5-3.1
6-386
7-0
8-1.9
9-3.1
Last Edit: February 09, 2024, 04:15:03 PM by Rob Capizzi
Rob Capizzi
Full Member
Reply #9 on:
February 09, 2024, 04:05:04 PM
New mje on b side
Rob Capizzi
Full Member
Reply #10 on:
February 09, 2024, 04:15:58 PM
There are a lot of lm431 models to choose from looking at mouser or digikey. Which should I choose?
Paul Birkeland
Global Moderator
Hero Member
Reply #11 on:
February 09, 2024, 04:34:21 PM
I'd use these:
https://www.mouser.com/ProductDetail/onsemi-Fairchild/LM431ACZ?qs=fAPocZeZcjirQBCPnqK0uQ%3D%3D
Be extra careful not to reheat the solder joints on the red LEDs as they don't do well with being soldered after they've been exposed to humidity for a long period of time. Also note that the MJE5731A will sink a lot of your soldering iron heat on the center leg, so leave your iron there much longer than you believe to be necessary.
When you have that board out, set your meter to beep for continuity and check each of the 75V zener diodes to be sure they aren't shorted. Based on the voltages you are reporting, that doesn't seem to be an issue, but it's so common that it's worth double checking.
Rob Capizzi
Full Member
Reply #12 on:
February 10, 2024, 02:34:38 AM
I also found the 220ohm resistor b7 to 18L is 293 ohm. B2 to 20L is 235ohm. Assuming I should replace, what resistor should I use? Just 1/4 watt carbon film, metal ox? 220?. Ordering from mouser. Thanks.
Last Edit: February 10, 2024, 03:56:36 AM by Rob Capizzi
Paul Birkeland
Global Moderator
Hero Member
Reply #13 on:
February 10, 2024, 06:00:43 AM
Those values aren't critical and can be left in the circuit.
Rob Capizzi
Full Member
Reply #14 on:
February 10, 2024, 10:28:58 AM
Thank you. I already have spare mje5731AG, 2n2907a, HLMP-6000, and zener diodes, is there any other recommended components I should order for future?
Bottlehead Kits
Legacy Kit Products
Paramount
