Bottlehead Kits => Legacy Kit Products => Foreplay III => Topic started by: Ritchie on September 06, 2010, 12:02:29 PM
I would like to remove the mono stepped attenuators and replace them with a 100k stereo stepped att.
I will be wiring the volume control in the normal position not the shunt configuration.
Is the 100K value pot ok in this circuit?
Thanks.
The 100K value is just fine. We use that value in the Quickie, SEX amp, Stereomour, and Crack.
Be aware that the maximum gain will increase by 10dB.
Paul,
I am assuming the extra 10 db is without the 33k resistors and if I left them in, it would be approx. 5db
increase at max. gain? Is this correct?
thanks.
Yes, that's correct. But if you are going to use a series resistor, even with a "normal" pot topology, I'd stay to a lower resistance, 50K or less. Otherwise you can get a high resistance before the tube at intermediate volume settings, and the Miller capacitance of the tube's grid will affect the treble.
Thanks Paul.
Hello Ritchie,
I might also recommend installing some series resistance between the input selector and the input of the 100k pot. In my personal preamps, I will often have a selectable resistance switched in here to get the best range out of the attenuator.
Yes, I was thinking of starting with the 33K series resistors that are already in the circuit.
I believe this should get me deeper into the 100K stepped attenuator I'm using.
Ritchie
