Bottlehead Kits => Crack => Topic started by: shoopdelang on December 02, 2017, 04:53:27 PM
Title: PN2907A transistors damaged?
Post by: shoopdelang on December 02, 2017, 04:53:27 PM
When I was adding the speedball upgrade I initial soldered the PN2907A transistor backwards. To remove it I had to put the soldering iron on the leads for quite some time. I have since finished the speedball upgrade and everything sounds good but I'm paranoid that somehow I damaged the transistor with the extra heat needed to remove it. Is it possible for the circuit to still function with a faulty transistor, just not optimally, or does the transistor just either work completely or not at all? Please forgive my ignorance on electronics, just hoping to learn :)
My measurements for the small board are:
OA 81V
IA 190V
B-A/B 0V
IB 190V
OB 78V (Should this be the same as OA?)
For the large board:
OA 113V (this is more than 10% of the accepted range. Could this be caused by the transistor? Is this a cause for concern?)
OB 113V (Same issue)
G 0V
B+ 189V
Title: Re: PN2907A transistors damaged?
Post by: Paul Birkeland on December 03, 2017, 05:23:58 AM
Your voltages look OK.
Post by: shoopdelang on December 04, 2017, 06:26:44 AM
Out of curiosity then, does a transistor just work completely or not at all or can it gradually degrade in performance?
Post by: Paul Birkeland on December 04, 2017, 07:01:06 AM
If you damage one, they usually short closed, so you would see more like 189V instead of 78.  Transistors do degrade over time, be prepared to think about replacing them in 50 years.
