Bottlehead Kits => Crack => Topic started by: samhillt on May 20, 2018, 02:38:00 PM
Hi,
I'm having a small problem with a whine in the left channel. Description
- It's very faint, and high pitched
- It's intermittent, sometimes very quickly fading in and out
- If I tap the crack it will make it stop (briefly)
- No change with volume adjustment
- Does it with input disconnected
I took some steel wool to the pins to clean, but I'm still hearing it.
Any ideas?
You might have to heat up your soldering iron and give your joints a good do-over, it’s the quickest solution.
If you post some pictures from your Crack’s insides, the Bottlehead crew could tell you if any of your solder joints look flaky.
That is indeed usually a flaky solder joint.
