Bottlehead Kits => Crack => Topic started by: Plumbum on October 20, 2018, 12:58:05 AM
Title: speedball help the upper right LED does not light [resolved]
Post by: Plumbum on October 20, 2018, 12:58:05 AM
Hello! the upper right LED does not light
Terminal Voltage (DC)
OA 71V
IA 185V
B-A / B 0V
IB 185V
OB 57V
Title: Re: speedball help the upper right LED does not light
Post by: Paul Birkeland on October 20, 2018, 05:49:55 AM
This is on the smaller PC board?
Do both LEDs remain lit on the 9 pin socket when you do this test (no need to mess with them either way).
Was the amp working OK prior to installing this board?
Post by: Plumbum on October 20, 2018, 07:21:47 AM
This is on the smaller PC board?  - Yes
Do both LEDs remain lit on the 9 pin socket when you do this test (no need to mess with them either way).- Yes
Was the amp working OK prior to installing this board? - Yes
I assembled the speedball completely, everything works, not only one light this diode
Post by: Paul Birkeland on October 20, 2018, 07:22:49 AM
OB 57V
This means the front PC board isn't working.  Can you pull the rear PC board out and recheck this voltage?
Post by: Plumbum on October 20, 2018, 07:41:13 AM
Foto:
Post by: Paul Birkeland on October 20, 2018, 07:49:13 AM
You have a backwards transistor on your small PC board.
Post by: Plumbum on October 20, 2018, 08:07:39 AM
PN2907A transistors, 2N2222A transistors,MJE-350 transistors, TIP-50 transistors
which to choose?
Post by: Paul Birkeland on October 20, 2018, 08:35:36 AM
Your small PC board has MJE350 and PN2907 transistors on it.  One of them is backwards.  It's visibly obvious because the shape of the transistor is inconsistent with the white outline on the PC board where it mounts.
Post by: Plumbum on October 20, 2018, 10:05:53 AM
I broke the transistor... pn2907a, there are analogues? I'm in Russia
Post by: Plumbum on October 20, 2018, 10:08:46 AM
Yes! I am very grateful to you, thank you very much!
Post by: Plumbum on October 20, 2018, 10:11:35 AM
Post by: Paul Birkeland on October 20, 2018, 10:12:11 AM
You'll probably be able to make more sense out of this than I can, but here is a potential source:
http://www.platan.ru/cgi-bin/qwery_i.pl?code=PN2907 (http://www.platan.ru/cgi-bin/qwery_i.pl?code=PN2907)
The prices seem pretty high, but shipping should be reasonable.
Post by: Plumbum on October 21, 2018, 01:17:14 AM
all perfectly!!! Thank you very much!
