Bottlehead Kits => Kaiju Stereo 300B amp => Topic started by: thunderfrenchie on November 17, 2018, 04:17:46 PM
Title: Problems with High Voltage Power Supply Test [resolved]
Post by: thunderfrenchie on November 17, 2018, 04:17:46 PM
Hi, I have already built a Kaiju with no problems. This is my second for mono blocking. I passed all the tests up until pg 47, high voltage test. Even after 10m minutes with black clip on 1U and red on 10U I only get 2.5VDC, far short of the 250. Thoughts?
John
Title: Re: Problems with High Voltage Power Supply Test
Post by: Paul Birkeland on November 18, 2018, 05:29:17 AM
This is the first test (without 300Bs)?
Can you post some photos of your power supply build?
Post by: thunderfrenchie on November 18, 2018, 06:21:45 AM
Unit has passed all bus and tube glow tests perfectly. The test it's failing is on p47 of manual.
Post by: Paul Birkeland on November 18, 2018, 06:35:10 AM
The wiring you have on your power transformer is incorrect; there is a missing wire.
Post by: thunderfrenchie on November 18, 2018, 07:53:48 AM
That did it. Thanks Paul. Resolved.
