Bottlehead Kits => Crack => Topic started by: mpribble on January 31, 2019, 04:49:13 AM
So got it done it was fun haven't done speedball yet I have it will do down the road at some point. Sounds good have to get use to it never had a tube amp before. Going to listen to for a bit might try different tubes not sure yet on that(wouldn't know which ones to get anyway).
I like the round over you put on the top edge of the base.
Thanks Paul, the base turned out great pics don't do it any justice. This thing gets very loud at about 9 o'clock on volume guess I need to turn down volume on computer. Was wondering what big tube I have all I can find on it is RCA 6A57 and 7552 which one is it?
It looks like an RCA 6AS7G.
Nice job! The base really makes it! Enjoy!
Congrats on your build!! Looks really nice!!
The 6AS7G is a great tube!!
Enjoy the fruits of your labor and be proud!!
Alex
The reflection of the lamp base gives a hint of how smooth the finish is. Nice work. Did you add the "picture frame" on the top of the base or is it all router work?
Did it with a router. The base was the hardest part to get the look i wanted. Had about three costs of poly and I goofed so I sanded it back down and started over. So now there is i think 8 or so costs of poly.
Wow! Beautiful casework and finish! Enjoy!
Joe.
have you see the crack FAQ on how to add the 75k/33k resistors to the pot to attenuate the signal a bit more? I had the same issue with not being able to turn past ~8 and it also having the issue of poor l\r matching at these lower levels. Doing this did the trick.
https://forum.bottlehead.com/index.php?topic=4295.0 (https://forum.bottlehead.com/index.php?topic=4295.0)
Also your build looks beautiful!
It doesn't take a rocket scientist to hammer out that mod, but it might help?
You'd think after trying to find that picture/how-to on at least on 3 different prior occasions I'd remember it was in the FAQ....but no, not even today. Probably not tomorrow either ;)
