Bottlehead Kits => Crack => Topic started by: tywoods on February 10, 2019, 02:45:15 PM
Title: New build wrong resistance question
Post by: tywoods on February 10, 2019, 02:45:15 PM
Hey guys,
I just built a crack to specs 220v. Checking the resistance, I get .41K instead of 2.9K. Everything else seems ok
7. .41
9. .41
B3 .41
B6 .41
Anyone know my mistake? Could it be I didn't twist the ends of the 10w 3K resisters well enough? It sort of came undone, but I filled it with solder anyway. I'm wondering how to redo it, and if that is my issue.
Title: Re: New build wrong resistance question
Post by: Paul Birkeland on February 10, 2019, 04:02:07 PM
That's an odd reading!  Can you upload a couple photos of the octal socket area?
Post by: tywoods on February 10, 2019, 09:58:51 PM
Paul,
I really appreciate the attention. This was my first time doing something like this. I tried to prioritize making a good connection over making it look good. Excuse the mess. Here are some photos.
Thanks again
(https://postimg.cc/sGhrtVNp)
(https://postimg.cc/nj5xRs0F)
(https://postimg.cc/8Jnp2XPV)
Post by: Paul Birkeland on February 11, 2019, 05:51:11 AM
That solder joint at 3U won't do.  Can you get the leads through the top hole?
Post by: tywoods on February 11, 2019, 08:00:49 AM
Thank you for the support Paul!
I used a solder wick to remove the solder, twisted the pair real nice put it through the hole and laid some solder over it. I also re-did B5. Not much change, :( I am reading between .39 -.43 on all 4.  Typically its a constant .40
I'm suppose to test with the black on 12U and then B3 for example with the red right?
Anything else you might see? Could you please tell me which connections these 4 tests rely on and maybe I can just redo them all?
Here are some more/new photos. Thank you sooo much
(https://postimg.cc/ZvbPw09s)
(https://postimg.cc/87bbrqZm])
(https://postimg.cc/75SWtsm5])
Post by: tywoods on February 11, 2019, 08:08:17 AM
Here are a couple of my tester. Same connections tested, but different settings on the tester, not 100% which is the right one to use.
(https://postimg.cc/YjZ4bb4K])
(https://postimg.cc/XBGrnyzz])
Post by: Paul Birkeland on February 11, 2019, 09:38:24 AM
If you put it on 20K, what readings do you get at 7/9?
Post by: tywoods on February 11, 2019, 10:05:13 AM
.40 for both
its 0 at 3U and .40 on 7U and 9U.
Post by: Paul Birkeland on February 11, 2019, 04:31:59 PM
Try carefully removing the 100uF cap between 6 and 7, then recheck and see if that changes the reading.
Post by: tywoods on February 12, 2019, 12:43:49 AM
Paul,
Thank you for your continued support.
I removed the blue 100u capacitor and no change. .40 on 7
I then removed both blue capacitors and got no change.
I then removed the solder from the entire 7 and 9 leads and tested the leads coming straight out of the 10W 3k resistors. and its .40 for both.
I'm like  ???
Post by: Paul Birkeland on February 12, 2019, 06:03:11 AM
If you measure one of the resistors itself, what do you get?  This may just be a meter issue.
Post by: tywoods on February 12, 2019, 06:29:47 AM
lol it is a cheap meter I bought in a 3rd world country.
Right out of the resistor (The opposite of the twisted side) both of them are reading .40.
Try another meter?
Post by: Paul Birkeland on February 12, 2019, 06:45:06 AM
I'd go ahead and just move on to voltages.
Post by: tywoods on February 12, 2019, 09:26:06 AM
Its ALIVE! OMGOMGOMGOMG   ;D ;D ;D ;D
Thank you sir. Much appreciated!
Post by: Jameson on February 12, 2019, 10:34:28 AM
If the multimeter was the problem, it doesn't cost too terribly much to get a relatively alright one. I bought this one (https://www.amazon.com/gp/product/B071JL6LLL/ref=ppx_yo_dt_b_asin_title_o04__o00_s00?ie=UTF8&psc=1) because my old one wasn't sensitive enough to measure voltage in a way that was meaningful for troubleshooting. It works pretty well!
