Bottlehead Kits => Crack => Topic started by: TypodCrow on February 28, 2019, 11:04:16 AM
Title: Rebuilding a Broken Crack
Post by: TypodCrow on February 28, 2019, 11:04:16 AM
TLDR;
I recently bought a pre-loved Crack that was unbelievably mishandled by USPS. While moving through the motions of insurance refund from the seller/USPS, I thought I'd take a crack (pun intended) at rebuilding it. This thread will be my outlet for questions/notes I have for the process.
Original condition when sold to me:
The last set of repairs done on this unit were outlined in this thread: https://bottlehead.com/smf/index.php?topic=11140.15
Pictures available here: https://imgur.com/a/5I3K7xF
I'm unsure whether the steps outlined in those posts were followed, however, it seems the point is moot since the amp was quite dishelved when it arrived. I will be doing a rebuild, instead of a repair.
Mods on the amp as recieved:
Rebuild steps:
Broken parts to replace:
These will be sourced from https://www.digikey.ca, since I am Canadian and need to purchase the output transformer from there anyways.
Big thanks to the Doc, and Paul, and Derek for helping choose suitable replacements. I'd be lost without you guys.
Tubes: Found them from a friend.
Hookup Wire: The ever helpful Maxhawk has agreed to include what I'll need with the tube switched board shipment.
250V 1A Fast Acting GMA fuse.
270ohm 5W resistor in the power filter (it is cracked in two).
Speedball's N2222A is blown (confirmed by checking terminal impedance when disconnected).
Thermal pads for the Speedball TIP50's. Mica, as suggested below.
Hookup wire for signal path. I know I'm ideally looking for 20 AWG PTFE Solid Core. Settling for PVC taking ths suggestion in comments.
I'm taking the 600V suggestion, instead fo the 300V so that I can use the remains for my Stax Amp build one day.
https://www.digikey.ca/short/pqrm95
Thanks for reading folks, and in advance for your help.
Nelly
Title: Re: Rebuilding a Broken Crack
Post by: Paul Birkeland on February 28, 2019, 12:29:31 PM
Stranded hookup wire is a good way to take a broken kit and make it worse.  Solid core is the only way to go.
If the 270 ohm resistor that crosses over the power transformer is the one that's broken, then you're better off replacing it with a 10W part so it will reach across all the way.  I don't think the Yageo has leads that are long enough.
Post by: TypodCrow on February 28, 2019, 01:08:17 PM
If so, how badly will I be hurting the sound by using PVC instead of PTFE? I'm losing on the order of 200 bucks to get a single color or PTFE 20/24 AWG for 100' that I don't need and don't have anyone to resell to.
If the 270 ohm resistor that crosses over the power transformer is the one that's broken...
When I was taking it apart, the choke was installed across the transformer. I'll recheck my hand drawn schematic and compare it to the manual to see if I misquoted it being the first 270ohm in the filter. Either way, I'll be putting it back together in the same fashion (choke across transformer).
Lastly, what are the minimum specs for the thermal pads on those TIP50's? That seems to be one of the last things I can't decide on for part ordering.
Post by: Paul Birkeland on February 28, 2019, 01:14:25 PM
You can use whichever thermal pad you'd like.  We (usually) supply mica ones.
Stranded wire doesn't hurt the sound, it's just impossibly hard to work with and the strands tend to go places where you don't want them.  The wire also doesn't stay where you put it.
Post by: TypodCrow on February 28, 2019, 01:19:54 PM
Stranded wire doesn't hurt the sound...
Awesome thanks; I'll do some more due diligence tomorrow. If I can't find any decently priced solid core, I'll try to find a soldering pot on campus (University) to help with the clean insertion of the leads into the terminals.
Post by: Paul Birkeland on February 28, 2019, 02:40:50 PM
While the solder pot can help, what you're left with is a stripped lead that's tough to bend around terminals.
When you're shopping for solid core wire, be sure if it's copper that it's plated with something and not just bare copper with PVC over it.  You want a barrier against oxidation on the leads that you strip.
Post by: Deluk on March 01, 2019, 01:08:43 AM
I don't know how the Bottlehead spares department works but wouldn't it be easier to just get the wire and components, those that were in the original spec of course, straight from them? Start from scratch. Build the new Crack and then add the SB after, as is the normal way to go. Mods later as and when.
Post by: Jameson on March 01, 2019, 02:11:26 AM
I picked up CAT5 and shielded twisted wire from Bottlehead before. Plus a bunch of other replacements for things I botched while building my kits.
Post by: TypodCrow on March 01, 2019, 04:58:02 AM
Unfortunately, shipping to Canada gets expensive. The solid core wire is the only thing I haven't yet found a true replacement for.
Post by: Jameson on March 01, 2019, 05:13:45 AM
I'd imagine a run of solid core plus shipping from BH (if they'd do it, I don't work there and don't speak for them, obviously) is probably less than what you'd mentioned in the opening post about losing a couple hundred on a huge spool.
Post by: 2wo on March 01, 2019, 08:36:02 AM
Parts connection is in Canada, they have wire...John
https://www.partsconnexion.com
Post by: Deke609 on March 01, 2019, 09:16:50 AM
I'm in Toronto, and I use the following from Digikey.ca.
Fatter PVC insulation (I believe this is the same brand/model of wire that BH ships with kits): https://www.digikey.ca/product-detail/en/general-cable-carol-brand/C2118A.12.03/C2118R-100-ND/16236 (ftp://www.digikey.ca/product-detail/en/general-cable-carol-brand/C2118A.12.03/C2118R-100-ND/16236)
Thinner PVC insulation: https://www.digikey.ca/product-detail/en/alpha-wire/422001-RD005/422001RD005-ND/4928094 (ftp://www.digikey.ca/product-detail/en/alpha-wire/422001-RD005/422001RD005-ND/4928094)
They both cost about $32 CDN for 100' plus I think about $8 shipping.  Both are tinned.
To save money, you could order just one color and wrap the ends in differently colored shrink tube or electrical tape to identify red, black, white, etc.
Post by: Paul Birkeland on March 01, 2019, 09:57:34 AM
The 300V rated wire is just fine for a Crack.
Post by: borism on March 01, 2019, 03:11:02 PM
I have bought small quantities of silver plated teflon wire on ebay a number of times. One seller (navships) was very reasonable and reliable.
Post by: Deluk on March 02, 2019, 01:45:52 AM
"Unfortunately, shipping to Canada gets expensive." At least get a quote from Bottlehead, keep it in the family as it were.
The parts you appear to need, including 2-3 metres of wire weigh ounces so I doubt if postage would be very much. A light jiffy bag is all that's needed. A CD is probably heavier. A 100m reel of wire, that's a different matter.
Post by: TypodCrow on March 02, 2019, 04:13:06 AM
Contacted the ream; will probably hear back Monday or Teusday. Until then I've taken the other suggestions and compiled a cart which I can easily checkout. I've also asked Maxhawk if he can kindly throw in a few feed of colored hookup wire (of the right kind) when he sends me the tube switching board. If this works out, then I'll be able to avoid dealing with 97' of white hookup wire sitting around until I need it in a few years.
OP has been updated with the suggestions I've taken from everyone here. Thanks again guys, I appreciate your input so far.
Post by: TypodCrow on March 16, 2019, 06:51:30 PM
Asking for some more help:
As I get ready to plan out the output transformer circuits, I'm realizing how  many things will need to be switched when changing from tube output to OT output.
To simplify this, can I wire the ground/-ve of the primary and the ground/0ohm of the secondary on the output transformer together? Or should I keep these separate? What am I sacrificing (besides an isolated ground) by connecting them together?
Post by: Paul Birkeland on March 17, 2019, 06:34:32 AM
I would listen to them before you commit to adding them to the circuit.  FWIW, we have never heard a Hammond transformer that we were happy with.
Yes.
No, I would connect them together.  This is a little safer, but you can try it either way.
Post by: TypodCrow on March 17, 2019, 08:34:28 AM
Thanks Paul; saves me another thing to switch on and off if I commit to them. I'll definitely listen first, but will most likely need to keep them on since I have low impedance cans and I'm fairly committed to the crack for now.
Post by: TypodCrow on March 18, 2019, 09:25:30 AM
Doing resistance and voltage checks now and getting some failures. The entire Crack has been rebuilt to as-recieved state (see first post for details). I have not plugged in headphones yet.
How might I debug what's going on? At first glance it seems the output caps are just not filtering out any DC?
Full voltage and resistance tables below. Inconsistencies with instructions highlighted:
Voltage (with tubes):
177
2182
30
4182
577
6108
7108
80
9108
10108
110
120
13180
140
15200
200
21218
A177
A20
A40
A50
A677
A70
A90
B177
B2180
B3108
B477
B5180
B6108
B70
B80
Resistance (without tubes, just in case it helps:
meter leads alone1.2
1inf
2inf
31.2
4inf
5inf
6inf
7inf
81.2
9inf
10inf
121.2
13*See note below*
141.2
201.2
221.2
B3inf
B6inf
RCA: GND1.2
RCA: L89
RCA: R90
Note on 13: slowly climbs to 200kohm when MM set to 200kohm limit; declines slowly to 0 when I flip multimeter to 2Mohm limit
Post by: Paul Birkeland on March 18, 2019, 10:02:42 AM
That's a relief.  This amp will destroy any headphones you plug into it.
Are the 2.49K resistors present on the headphone jack?  Can you post some photos of your work?  Is the headphone jack grounded exactly as it is in the manual?
Post by: TypodCrow on March 18, 2019, 10:31:26 AM
Pictures are a little hard to snap with the massive caps and the Speedball boards in the way but I'll do my best with the angles I can sneak in. The pictures are taken with Maxhawk's tube switching speedball board installed but the state is the exact same if I use the stock Speedball board. I have ensured I am in 12AU7 mode on the switching board.
Note: All 6 LED's are lit.
Yes they are (picture attached).
No. The jack's S terminals (both) are connected to 12. It is also grounded to 3 (which routes to the volume pot's ground terminal) instead of pulling a wire all the way across from the pot's ground directly. 3 also grounds both speedball boards (that is all ther connections at 3).
The T and R connections of the headphone jack are hooked up to 10 and 6, which are only wired to their respective output caps.
Post by: TypodCrow on March 18, 2019, 10:59:20 AM
I think i know what it is. The resistors only cut across the headphone jack, but don't ground to the sleeve pin. I'm going to short the three right side pins of the headphone jack (view orientation of the picture attached in my last reply to this thread). That will solve it.
Dumb derp; my apologies.
Post by: Paul Birkeland on March 18, 2019, 12:50:22 PM
Yes, that's the issue.  In Crack 1.0, these resistors go down diagonally to the sleeve terminal, then in 1.1 we ground out all of the terminals that are shorted when no headphones are plugged in, then connect the resistors to this ground.
Post by: TypodCrow on March 18, 2019, 12:58:27 PM
It's a great feeling finally hearing this beauty. The OPT's I can't judge yes since I only have low impedance loads hut I'll definitely borrow my friend's HD600 to get an understanding of how they're affecting SQ.
