Bottlehead Kits => Crack => Topic started by: Nayr on September 27, 2019, 12:33:11 AM
Title: Left channel noise on Crack w/ Speedball
Post by: Nayr on September 27, 2019, 12:33:11 AM
Hi,
I'm having a couple issues that are resulting in left channel noise, it alternates between a light scratchy crackling sound and semi high pitched electric buzzing.
I've done a lot of wicking solder away and then resoldering, I put particular effort into:
I've also carefully tired to redo the connections on the 9 pin socket but was a bit worried about overheating and cooking the LEDs.
One area that I have not properly wicked and resoldered is the area around the 270Ω 5W wirewound resistor and the 270KΩ 1W resistor (13L), I can't really reach it properly and the leads for the stuff around there are pretty short.
Could I get some help narrowing down where the issue is? Or at least pointed towards all the left channel things. :P
I can provide pictures and voltages and stuff, but I thought that this post was already too long; I'll wait for confirmation of what would be most useful first.
Ryan
Title: Re: Left channel noise on Crack w/ Speedball
Post by: Paul Birkeland on September 27, 2019, 04:24:31 AM
If the issue goes away with the amp upside down, that tends to suggest a loose connection on one of the sockets.  Just in case, you could also perform this mod in case you have a very noisy powerline.
https://forum.bottlehead.com/index.php?topic=11676.0 (https://forum.bottlehead.com/index.php?topic=11676.0)
Post by: Nayr on September 28, 2019, 04:39:20 AM
I ended up redoing both sockets today, sadly still having issues.
It might actually be interference from my PC, which is a bit odd as I didn't have any issues before and didn't change anything, and I thought the scratchy sound was a bit different to what interference normally sounded like. I did notice today that for a little while there was a bit of buzzing in the right channel too though.
I'll try the mod when the parts eventually arrive, I'll probably order them tomorrow; it's apparently hard to get that part in Australia.
Post by: Paul Birkeland on September 28, 2019, 06:24:00 AM
This would also work just fine:
https://www.digikey.com.au/product-detail/en/comchip-technology/1N5401-G/641-1314-1-ND/1979679 (https://www.digikey.com.au/product-detail/en/comchip-technology/1N5401-G/641-1314-1-ND/1979679)
Post by: Nayr on September 28, 2019, 07:43:27 PM
I was looking at Digikey but I think that they ship from the US as well.
I ended up buying the diodes that the other guy suggested from Jaycar because it is nearby (his now deleted post referenced the 1N5408 3A 1000V). Would that particular one work? I installed them* earlier today but the noise is still there.
Also, does this mod help at all with noise from WiFi routers?
* Edited for clarity.
Post by: grufti on September 28, 2019, 08:30:03 PM
You say "it" when you refer to the diode. Do you mean one diode [it] or two? I would use "them" to talk about two diodes and you need two installed in opposite directions for the noise suppression to work. Your 1N5408 should work just fine.
Post by: Nayr on September 28, 2019, 09:38:01 PM
I mean two, I bought two of them and installed them per the post PB provided earlier.
