Bottlehead Kits => Crack => Topic started by: Krishk on October 10, 2019, 04:11:12 PM
Title: Tubes won't fit
Post by: Krishk on October 10, 2019, 04:11:12 PM
Hi, I'm   pretty new to building tube amps, and I just got to the glow test of the bottlehead crack. The manual states that I need to insert the tubes into the 9 pin and 8 pin sockets, but the tubes won't fit into the sockets. I checked twice to see if I installed the sockets correctly and I did. Is there a special method not mentioned in the manual to insert the tubes? Is it possible I was sent the wrong tubes or somehow damaged the sockets? Thanks
Title: Re: Tubes won't fit
Post by: Jameson on October 10, 2019, 04:55:42 PM
Do you have the pins oriented properly? There’s a gap in the pins to help you orient them, and a tab in the middle post of the 6080
Post by: Krishk on October 10, 2019, 05:13:32 PM
I see now thank you, I just had to apply a bit more force to the smaller tube to fit it in the pins.  Once again thanks for the help
Post by: adydula on October 11, 2019, 02:20:09 AM
Let me add this:
If you plan on tube swapping in search for audi nirvana, remember the force it took you to insert etc.
When you try to remove vacuum tubes you will pull and gently rock a little back and forth to get the tube to come out.
At the same time the pins in the tube socket are going to move and if your solder joints are not good wires, connections may come loose or
crack in the solder joints..
So make sure those solder joints are really good and be careful removing and replacing....
FYI...YMMV
Alex
Post by: Krishk on October 11, 2019, 07:18:28 AM
Let me add this:
FYI...YMMV
Alex
Thank you for the tip will definitely into consideration. Is it typical for force to be used when inserting and removing tubes?
Post by: Paul Birkeland on October 11, 2019, 07:21:01 AM
If it requires no force to push the tube into the socket, then the socket won't make good contact with the tube pins and it needs to be replaced.
