Bottlehead Kits => Legacy Kit Products => Crack-a-two-a => Topic started by: teamrushpntball on November 20, 2019, 01:41:04 PM
Is there any reason I can't swap a neutrik female xlr into the headphone jack? Just bridge the two negative leads together and leave everything the same?
Seems as easy and a little cheaper than replacing the connector on my cables.
Yes, you can do that. You can also just make a 1/4" male to 4 pin XLR female adapter as well.
Thanks for the reply, may make the adapter since it's more likely any future headphone cables will be 1/4" anyway. Make the trip down to Partsexpress tonight and see what they have.
