Bottlehead Kits => Crack => Topic started by: kattjaevel on February 16, 2020, 09:34:49 AM
Title: Sound faded away from one channel / High voltage readings on Crack [resolved]
Post by: kattjaevel on February 16, 2020, 09:34:49 AM
Hi! When I first completed my Crack resistances and voltages checked out when measured, but after a while the sound in the right channel faded out.
Now when I measure the voltages I get some weird values. Between 12 and below points it's higher than expected. The A8 LED doesn't light up, nor does the topmost side of the 12AU7 glow
A6 145V,
B1 145V,
B3 145V
Any clues where to start figuring this out?
Title: Re: Sound faded away from one channel / High voltage readings on Crack
Post by: Paul Birkeland on February 16, 2020, 04:47:10 PM
Do both halves of the 12AU7 glow?  Can you very carefully measure the DC voltages at A3 and A8?
Often times an issue like this is the solder joint at A4/A5.  If it's not well connected, half of the 12AU7 will be extinguished and you will get all of these symptoms.
Post by: kattjaevel on February 17, 2020, 04:31:23 AM
No, the filament attached to A8 doesn't glow.
I went over and redid the solder points at A4 and A5... They looked OK before but perhaps a bit better now. A4 doesn't have the best physical contact. However, they measured 0 Ohm impedance to ground before and after.
A3 measures 1.6V, A8 measure -1.0V DC...
Edit: I switched to the original 6080 (Apparently I had used another I had laying around) and with it, one of the sides does not glow as much as the other.
Post by: Paul Birkeland on February 18, 2020, 10:15:05 AM
Post by: kattjaevel on February 19, 2020, 07:26:34 AM
some images:
(https://i.imgur.com/u3oGAeR.jpg)
(https://i.imgur.com/FxSfPo2.jpg?1)
(https://i.imgur.com/WbAKOKy.jpg)
Post by: Paul Birkeland on February 19, 2020, 03:53:16 PM
1.  Power transformer terminal 9 has a wire going through it that almost touches power transformer terminal 10.  If those should ever touch, you will blow fuses endlessly until you trim that.
2.  Are both black wires captured by solder where they meet on the headphone jack?
3.  Is the wire that connects to A4/A5 passing through A4?  It looks like perhaps not?
Post by: kattjaevel on February 20, 2020, 03:34:52 AM
Thanks Paul for the feedback!
I trimmed the cable at 9, was about 3mm of gap but it wouldn't be nice blowing a fuse during all of this. Resoldered the black wires at the headphone jack (they looked OK before). The wire goes through A5 and bends up at A4 so it locks in place. I had some more time today so will attach some more pictures that might be helpful. Starting the project a few years back I was using a really poor soldering iron (very big tip and wasn't heating properly at the tip) and had matching skills. So lots of joints look dirty. Is that something that could cause issues and I need to redo?
(https://i.imgur.com/YcfS5gY.jpg)
(https://i.imgur.com/fHG84QM.jpg)
(https://i.imgur.com/BMR3KAe.jpg)
(https://i.imgur.com/x1EdQVO.jpg)
(https://i.imgur.com/wtvmAm5.jpg)
(https://i.imgur.com/fZn4XFZ.jpg)
(https://i.imgur.com/TUd9Pyn.jpg)
Post by: adydula on February 20, 2020, 06:42:37 AM
Remember if your iron isnt heating properly, you need to keep the tip clean before using, by rubbing on a wet sponge and using some flux....if you dont keep it clean you
will not get good heat at the tip needed for proper soldering.
Also sometimes the tip can become loose and needs to be tightened in the heating element....
I mention this because you stated having issues with heating and the tip...
Alex
Post by: kattjaevel on February 20, 2020, 07:44:18 AM
Yes, I have gotten a new iron since and went over most but not all joints, some are quite hard to reach  ;D ;D
Post by: Paul Birkeland on February 20, 2020, 10:18:06 AM
You can try a small wire jumper between A3 and A8.
Post by: kattjaevel on February 21, 2020, 06:26:40 AM
I bridged A3 and A8 and still no action with the A8 connected filament. Is my tube bad?
Post by: Paul Birkeland on February 21, 2020, 06:52:08 AM
So no change in voltage at terminals 1 and 5?
Is my tube bad?
There's about a 1/1,000 chance that your tube is bad.  There's a 999/1,000 chance that there's a bad solder joint, broken wire, etc. in the amp causing this problem.  This is based on your information that one channel just kind of faded off on its own.  If maybe the 12AU7 was dropped or something was dropped on the amp, then the channel dropped, that would be different.  When a tube goes from good testing to bad testing, it doesn't just turn off immediately.  There will be a period of a few thousand hours where things just don't sound right before things get so ugly sounding that you go looking for what's wrong.
Can you tell me if both halves of the 12AU7 glow?  I asked before and I think you thought I was referring to the LEDs.
Post by: kattjaevel on February 21, 2020, 07:35:28 AM
No, the upper side of the 12AU7 still doesn't glow. That's what I tried explaining when I wrote that the filament doesn't glow. Probably incorrect terminology. This kit is very old if that adds to it. I bought it some 7-8 years ago.
T1 reads 145V,
T5 reads 92V
Post by: Paul Birkeland on February 21, 2020, 09:19:05 AM
Inside the 12AU7 there are two plate structures.  Each plate structure has a heater that runs up the middle.  You may be able to see the bottom of each heater structure and/or the top of each heater structure.  If you can't see glowing dots on the top of each plate structure, then you need to look at the bottom of each plate structure to see if you have a glowing dot on each side.
If you have two glowing dots on the bottom of the tube, then that's useful information.  If you aren't sure, consider posting a photo of your tube glowing in a dark room.
Post by: kattjaevel on February 21, 2020, 10:14:05 AM
Sorry Paul, I see how my response may be unclear. I see that the heater closest to the front of the chassis, the one that sits on top of A3, glows. But the one that sits on top of A8 doesn't.
Post by: Tom-s on February 21, 2020, 10:48:41 AM
On the small sockets. Check if pin 4 and 5 are still properly connected.
Post by: kattjaevel on February 21, 2020, 11:06:24 AM
What is a good way of testing that? Visually they look similar, not one that is pulled out further or anything. When I look at them from the top I can see both sockets look just like the others.
Post by: Paul Birkeland on February 21, 2020, 04:48:12 PM
OK, this is usually an indication that the solder joint at A4/A5 is not doing its job.
Post by: kattjaevel on February 23, 2020, 09:51:44 AM
I redid the soldering on A4/A5, as well as B7/B8 (both from the transformer and from B to A). I can with confidence say that these connections shouldn't be an issue any longer. I made sure that they were solid and didn't move a millimeter before soldering and made sure to solder properly. Redid voltage readings. Still the "left" side of the board measure too high. Here are some outstanding values...
T1: 140V
T2: 160V
T4: 160V
T5: 95V
T7: 140V
T9: 108V
A6: 140V
B1: 140V
B3: 140V
Post by: Paul Birkeland on February 23, 2020, 09:54:21 AM
Do both halves of the 9 pin tube glow?  If not, and you're confident that your connections are good, I would replace the 12AU7.  If the new 12AU7 has one half that doesn't glow, then you will need to go back over those heater connections.
Post by: kattjaevel on February 23, 2020, 10:14:57 AM
No, still only the bottom half of the 9-pin tube glows. I'm quite certain that these connections are solid. They didn't budge at all no matter how much I tried moving them before soldering and the physical connection between the pin and wire was solid. I'll try with another 12AU7. Thanks.
In the meanwhile, is there anything else in the chain that could be causing these voltage issues or is it because the 12AU7 doesn't "draw" any current? Could for example my A-socket pins have been pulled out so that they don't connect to the tube any longer? Can I measure something like that? I tried shining a flashlight down the sockets and saw nothing apparent that would be the issue of the sort, but guess I might as well ask an expert. Appreciate all the help :)
Post by: Paul Birkeland on February 23, 2020, 10:58:33 AM
If only one half of the 12AU7 is heated, then only half the tube will operate, and you'll get flawed voltage measurements and no sound out of that channel.  That's the impetus for focusing only on that and not looking for problems elsewhere.
Post by: kattjaevel on March 12, 2020, 03:13:10 PM
Well, the 12AU7 finally arrived in the post. Swedish postal service at it's finest, 3 week delivery... anyways, I installed the new 12AU7 and redid resistance and voltage measurements, everything works now :)
