Bottlehead Kits => Eros Phono => Topic started by: heavycowboy on April 13, 2020, 09:19:02 AM
Title: Step Up Transformer Installation
Post by: heavycowboy on April 13, 2020, 09:19:02 AM
Hey All,
Thinking of trying an MC cart with my Eros 2 . Where can I find detailed instructions on how to install a pair of step up transformers?
Thanks in advance,
Todd
Title: Re: Step Up Transformer Installation
Post by: Chris65 on April 13, 2020, 12:33:42 PM
Quote from PB Sept 2018: Instructions for proper installation of step-up transformers will be forthcoming shortly.
(first sticky in this thread)
Post by: Paul Birkeland on April 13, 2020, 01:53:36 PM
Well, there are several different models of step-up transformers that you could use depending on the cartridge you plan to use, so there's no one size fits all set of instructions that will cover absolutely everything.
In general:
1.  Pop the resistors out of each RCA jack that go to pin 9 on each EF86 (leave them attached to the socket, just pop out the end sitting in the solder cup of the RCA jack).
2.  Remove the 47K loading resistor on each RCA jack.
3.  Reconnect them at terminals 2 and 17.
4.  Install step-up transformers.
5.  Wire step-up primary wires to each RCA jack.
6.  Wire step-up secondary wires to terminals 1/2 and 16/17.
7.  Install loading resistors as recommended by the SUT manufacturer and/or your cartridge manufacturer.  You can load the primary or the secondary of the SUT relatively easily by either using loading resistors across the RCA jacks (loading the primary), or loading resistors between 1/2 and 16/17 (loading the secondary).
At some point I'll post some photos of my Eros 2 that has this installed.  I had taken some a long time ago but I was unable to locate them.
Post by: heavycowboy on April 14, 2020, 03:18:32 AM
Hi Paul,
Appreciate the quick reply and the detailed instructions. While it all makes sense, a picture of your installation would prove helpful.
Todd
