Bottlehead Kits => Jaeger Speaker => Topic started by: Jameson on June 05, 2020, 03:51:59 PM
Title: One speaker louder than the other
Post by: Jameson on June 05, 2020, 03:51:59 PM
I have been debating about this for the past month, whether one channel is louder than the other. It seems to me that the left channel has more prominent vocals and higher frequencies. To see where the issue is I’ve done the following:
In my mind, that leaves a few possible causes for the imbalance that I need to test:
Any possibilities I’m missing? Anything else I should consider or test?
Title: Re: One speaker louder than the other
Post by: kgoss on June 05, 2020, 04:35:27 PM
One time I had the image shifted slightly off center and it took me a long time to figure it out. Turned out I had the + and - speaker wires swapped on one speaker. So the speakers were out of phase with each other. Drove me crazy trying to find the problem. So if your Stereomour II and Kaiju amps sound the same and the problem is the midrange you might want to check the internal Jaeger wiring to make sure you have correct phase on all the drivers. Good luck!
Post by: Jameson on June 05, 2020, 04:47:48 PM
Interesting! I’ll check that as well. Thank you!
Post by: Paul Birkeland on June 06, 2020, 04:53:08 AM
I had this happen with my Jagers once and it was a loose connection in one of the speaker cable jumpers (a loose connection between a banana and the speaker wire itself).
Post by: Jameson on June 06, 2020, 10:52:16 AM
I am so baffled. I think there are two things happening: I think one speaker is slightly louder than other in some parts of the range, and I think the problem is exacerbated by weird acoustics in the room. I swapped the speakers and the sound is pulling ever so slightly to the right now, but generally more centered.
Post by: Jameson on June 06, 2020, 01:51:36 PM
I moved a couple things around and I think I found the perfect spot. Now nothing, including me, can ever move. It’s a shame I’ll miss the birth of my first child.
