General Category => General Discussion => Topic started by: atchicago on June 23, 2020, 09:55:32 AM
Title: scratchy sound (s.e.x 2.1)
Post by: atchicago on June 23, 2020, 09:55:32 AM
good afternoon, folks,  Though I have been reading this forum for a long time, this is my first post here ever!
what happens is that I have some scratchy sound, sometime signal drop offs. So I changed the volume pot to alps. It works, but the scratchy sound still comes, usually after the amp runs for a while.
So I am spray some crc electronics clearner into the rca jacks. Qtips are used to clean it.
In case I need to replace the rca jack, can someone tell me how to get the parts?
Title: Re: scratchy sound (s.e.x 2.1)
Post by: Paul Birkeland on June 23, 2020, 10:38:49 AM
How are your DC voltages?
Do you get the scratchy sound with the pot all the way down?
How have you determined that you need to replace the RCA jacks?
Post by: atchicago on June 23, 2020, 12:04:45 PM
thanks for the prompt reply, Paul.
when the scratching sound starts, I tried to wiggle/twist the rca cord, or unplug/plug the rca cord, it changes (better or worse) the scratching, sometime the annoying scratching noise even went away for a short time period. That makes think of cleaning the rca jack.
I have not tried turning the pot all the way down. I will for sure try that next time when the noise starts.
I do not understand the DC voltage part. Can you please tell me how to test it?
Thank you very much!
Post by: Paul Birkeland on June 23, 2020, 02:18:15 PM
The DC voltage check is outlined in the manual.
Are the jacks physically nice and tight?  They may just need to be tightened.
Post by: atchicago on June 24, 2020, 12:56:44 PM
jack is tight. when the pot is turned all the way down, there is no sound at all.
could it be the jack?
Post by: Paul Birkeland on June 24, 2020, 03:06:56 PM
If the scratching sound goes away when the volume pot is all the way down, that would suggest that the jacks could be loose/worn.
Post by: atchicago on July 02, 2020, 04:20:28 PM
Thank you very much, Paul.
Where can I get the parts of RCA jacks?
have a great weekend!
Post by: Paul Birkeland on July 03, 2020, 07:45:45 AM
There were a few different jacks that went into the kits over the years, you would have to post a photo of the jacks you have on your kit for us to know for certain.
Alternatively, you could take one out and measure the hole diameter, then go and pick some new ones on your own.
Post by: atchicago on July 03, 2020, 07:58:30 AM
wonderful!  :D Here are the pictures.  Let me if you need me to take another shots
By the way, I also want to buy the original or equivalent headphone jack.
Post by: Paul Birkeland on July 03, 2020, 08:47:24 AM
Those were the Chinese jacks that we were getting between about 2008 and maybe 2015.  The quality dropped substantially after a certain point and we switched to a different jack that fits in a larger hole.
This would be a pretty close substitute, though they are currently out of stock:
https://www.parts-express.com/parts-express-chassis-mount-rca-jack-pair--091-1120 (https://www.parts-express.com/parts-express-chassis-mount-rca-jack-pair--091-1120)
If you want to drill out the holes in the panel to 10mm, you could install the Neutrik jacks we use now.
What's going on with the headphone jack?
Post by: atchicago on July 03, 2020, 11:50:42 AM
thank you so much, Paul
what are the measure of these rca jackets?  I might be able to find them on ebay.
for instance this one (3/8" mounting hole, chassis up to 3/16" thick)
]https://www.ebay.com/itm/Gold-Plated-RCA-Jack-Panel-Mount-Chassis-Socket-Red-and-Black/353096184525?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3D19c50aa19a2849abae14da400f3fe423%26pid%3D100675%26rk%3D1%26rkt%3D15%26mehot%3Dnone%26sd%3D353096184525%26itm%3D353096184525%26pmt%3D0%26noa%3D1%26pg%3D2380057&_trksid=p2380057.c100675.m4236&_trkparms=pageci%3A6fa5f84a-bd76-11ea-b6ce-74dbd180dcfe%7Cparentrq%3A16a3bd911730a99b185360f7fff9c3b8%7Ciid%3A1[url] (https://www.ebay.com/itm/Gold-Plated-RCA-Jack-Panel-Mount-Chassis-Socket-Red-and-Black/353096184525?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3D19c50aa19a2849abae14da400f3fe423%26pid%3D100675%26rk%3D1%26rkt%3D15%26mehot%3Dnone%26sd%3D353096184525%26itm%3D353096184525%26pmt%3D0%26noa%3D1%26pg%3D2380057&_trksid=p2380057.c100675.m4236&_trkparms=pageci%3A6fa5f84a-bd76-11ea-b6ce-74dbd180dcfe%7Cparentrq%3A16a3bd911730a99b185360f7fff9c3b8%7Ciid%3A1[url)[/url]
or, this one on ebay
https://www.ebay.com/itm/Genuine-New-Neutrik-Rean-NYS367-2-Gold-Plated-RCA-Jack-Phono-Chassis-Socket-Red/331091532619?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3D19c50aa19a2849abae14da400f3fe423%26pid%3D100675%26rk%3D2%26rkt%3D15%26mehot%3Dnone%26sd%3D353096184525%26itm%3D331091532619%26pmt%3D0%26noa%3D1%26pg%3D2380057%26brand%3DREAN&_trksid=p2380057.c100675.m4236&_trkparms=pageci%3A6fa5f84a-bd76-11ea-b6ce-74dbd180dcfe%7Cparentrq%3A16a3bd911730a99b185360f7fff9c3b8%7Ciid%3A1 (https://www.ebay.com/itm/Genuine-New-Neutrik-Rean-NYS367-2-Gold-Plated-RCA-Jack-Phono-Chassis-Socket-Red/331091532619?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3D19c50aa19a2849abae14da400f3fe423%26pid%3D100675%26rk%3D2%26rkt%3D15%26mehot%3Dnone%26sd%3D353096184525%26itm%3D331091532619%26pmt%3D0%26noa%3D1%26pg%3D2380057%26brand%3DREAN&_trksid=p2380057.c100675.m4236&_trkparms=pageci%3A6fa5f84a-bd76-11ea-b6ce-74dbd180dcfe%7Cparentrq%3A16a3bd911730a99b185360f7fff9c3b8%7Ciid%3A1)
for the headphone jack, I just want to get a backup.
Post by: Paul Birkeland on July 03, 2020, 12:36:17 PM
The first set of jacks you linked to are identical to what you have now.  Do be aware that the quality control issues could still be a big problem, and what we observed was that you couldn't tighten the nut on the jack enough to hold it in place without the threads disintegrating.
NYS212 is the HP jack.
Post by: atchicago on July 03, 2020, 02:15:12 PM
thank you very much for your help. really appreciate it.
have a good weekend!~
Post by: grufti on July 03, 2020, 04:47:47 PM
The Rean jacks on eB should be OK. Rean is the other brand by Neutrik. Neutrik can't make everything in Liechtenstein. The country is too small. The seller has those in white also for the same price. You need to scroll down quite a ways to find those. There might even be black ones hiding further down.
