Bottlehead Kits => Legacy Kit Products => Stereomour => Topic started by: Comity on February 16, 2021, 09:12:59 AM
Hi All,
I have a question that may be obvious to the more experienced. Should one do a hum adjustment each time the power tubes are changed out? I recently noticed a hum in one channel of my Stereomour (previously masked by the crackling noises from having my WIFI router too close to the amp), and when I switched the power tubes the hum changed channels, so it is definitely tube related. I have been using JJ's 2A3 tubes since about 2015, and the tube that has more hum appears to have a much darker glass support at the bottom of the tube compared to the non-humming tube. The glass support is almost black compared to the other tube in which the glass support is still clear. This got me to wondering if I should have done a hum adjustment when I first installed the JJ's. I did the hum adjustment when I built the Stereomour with the original Sovteks. Also, would there be any reason to go back and do any resistance or voltage checks? Those were all within normal range after I built the amp. Thanks for any input on this topic.
Yes, you need to check the hum trim any time you change the tube.
Thanks Doc....I should have realized that. Do you think that not adjusting the hum trim could have played a role in causing the tube to hum prematurely and also darken the glass support?
Nope. You say the tube is 6 years old. That's a pretty healthy lifetime for a 2A3. Have you tried trimming out the hum on the tube in question? It certainly wouldn't hurt to do a voltage check to see if the tubes are drawing extra current from age.
Thanks Doc. I appreciate your input and will go ahead and trim out the hum on the questionable tube and check voltages. It's probably a good idea to go ahead and confirm everything is still in spec.
Is it okay to trim the hum trim while the amplifier is connected to speakers. ie, check the hum trim by ear rather than instruments?
Yes, it works quite well unless the hum is inaudible - in which case, you don't need to get it better :^)
