General Category => General Discussion => Topic started by: Markkr on February 16, 2021, 03:48:24 PM
Title: Addicted
Post by: Markkr on February 16, 2021, 03:48:24 PM
Addicted to building these kits!
I started with a pair of Cracks+SB... now have a C2A that I absolutely LOVE... I have no desire to change my headphones, as I’m perfectly content with my complete collection of Senn “6 series”.
I’d like to now focus on building a comparable speaker rig. I want the C2A + HD600 in speaker form for my home office. The speakers would need to be bookshelf size.
Can I get a recommendation for BH amp/pre-amp and speakers that would sound like C2A+HD600? (I’m perfectly happy to DIY the speakers as well)
Title: Re: Addicted
Post by: Jamier on February 16, 2021, 04:27:55 PM
How large is your room? You need to consider your speaker sensitivity when selecting your amplifier power capability. This is very much like the previous thread. If your looking for headphone like sound from a loudspeaker you may be disappointed,  as no loudspeaker will give you that between the ears image. But,  if you are willing to trade  for a forward imaging version of that, a Waveguide TM (tweeter on top, midwoofer on bottom) or a waveguide TMM, like the Jaegers, may make you very happy, as long as the speaker of choice has voice coil alignment and a true, second order crossover.
Jamie
Title: Re: Addicted
Post by: Markkr on February 16, 2021, 04:33:37 PM
The room is small, and full of “stuff” as its my home office + hobby room + guest room... (11’ x 12’ ). Theres no floor space, so wall mounted speakers or bookshelf would be a requirement. Speakers could be placed up to 9’ apart at most. I get it, this is not an ideal listening room... and I’m okay with the forward presentation, I simply want the warm and clear sound that I get from the C2A + HD600’s.
Title: Re: Addicted
Post by: Jamier on February 16, 2021, 04:51:58 PM
I’m not sure anyone has the perfect listening space. Nine feet apart is probably too far apart for that space, but that’s OK, you can probably close that a little, right? Wall mounting is not a great solution unless the speakers are specifically designed for that purpose. Do you have room to stand mount a, say,a 1/2 cubic foot enclosure? That would be roughly 9 * 12 * 16.
Jamie
Title: Re: Addicted
Post by: Doc B. on February 17, 2021, 09:50:23 AM
Take a look at Blumenstein Orcas with an active subwoofer and a Stereomour II. Headphones and speakers will always sound different. But that combination of amp and speakers sounds very good and images quite well in a smaller room. The Orcas do pretty well mounted on the wall.
Title: Re: Addicted
Post by: Markkr on February 17, 2021, 02:11:23 PM
Oh I like the look of that, is a subwoofer required for the Orcas?
I think I’m going to order the StereomourII this week, seems to be amp solution I’m seeking (I was originally considering the S.E.X.)
Title: Re: Addicted
Post by: Markkr on February 17, 2021, 02:12:10 PM
Jamie
Unfortunately I have zero floor space... just too many things going on in that room. I can do any spacing 9ft or less.
Title: Re: Addicted
Post by: Karl5150 on February 18, 2021, 04:41:42 AM
Addicted...you and me both brother!
You don't mention if you are going to be listening primarily while working at a desk or you want it set up for general listening in the room.
If a desk with limited space is a consideration, a SEX amp will save a surprising amount of real-estate. While I would never try to talk a fellow BH down from an SII (it is my main amp) there is a good dose of magic to be found listening to a small single-driver plus powered sub set up through a SEX amp in the near-field.
Then build the SII for the den system...and the Kiaju, or two, for the big rig in the living room...
Karl, Bottlehead enabler
Title: Re: Addicted
Post by: Doc B. on February 18, 2021, 08:17:54 AM
RE Orcas and a subwoofer. Like everything in audio this is a matter of taste. For me a subwoofer is mandatory. That is simply my taste and not a pontification by some self proclaimed guru. This is also not dissing the Orcas at all, they get good bass for their size and I imagine there are folks out there who prefer them without a sub. Bear in mind those are 3" drivers. Physics is physics.
Title: Re: Addicted
Post by: Karl5150 on February 18, 2021, 10:36:04 AM
What Doc said.
Not Orcas but my Fostex based speakers are very similar. There are times that I neglect to turn on the sub amp and don't notice it until a particular tune comes on where I miss the bottom octaves. They will play to very satisfactory volume levels within the confines of a similar sized office with just a few watts on tap.
Title: Re: Addicted
Post by: Markkr on February 18, 2021, 01:09:59 PM
Thanks guys. I sincerely appreciate the enablement! (Though my wife would disagree)
More often than not, this will be utilized while working during the day... maybe the S.E.X.  Would be enough... price is less of a concern vs space consumption.
Title: Re: Addicted
Post by: Hank Murrow on February 19, 2021, 10:49:41 AM
Hey Markkr;
I have a pair of Orcas sitting on their subs playing in my 14x18 room very nicely driven by a Custom Bottlehead 2A3 amp. The only limitation I see is the limited power handling of the speakers. However, I have PB building a pair of Jäegars for me, and I expect that my new speaker/amp combo to solve my listening demands beautifully for the rest of my life(82 now), from Pablo Casals, to Gustave Mahler, to Keith Jarrett. You have been offered good counsel here on the BH Forum, so good luck and happy listening!
Cheers, Hank Murrow
Title: Re: Addicted
Post by: Doc B. on February 19, 2021, 11:01:08 AM
We had a pair of Orcas run by a S.E.X. amp and later by a StereomourII in our previous packing room, for about 8 years. Pretty sure Eileen wishes I would get off my butt and set up a system in the current packing room.
Title: Re: Addicted
Post by: Thermioniclife on February 19, 2021, 11:22:58 AM
It would do you good dear sir to please the Queen as we all know when the Queen is not happy her minion will not be happy!!  ;D
Title: Re: Addicted
Post by: Markkr on February 19, 2021, 02:24:06 PM
I know this isn't the Blumenstein Orca forum... but you guys seem very informed about them.
Are they prebuilt? Are the cabinets finished?
I love the bamboo looking ones, but they’re not in stock.
Title: Re: Addicted
Post by: Jameson on February 19, 2021, 03:31:30 PM
Yeah, they’re prebuilt and finished. You could email Clark and see what he thinks timelines look like to get stuff back in stock. I emailed him once and he called to chat for 20-30 minutes. Real nice guy.
Title: Re: Addicted
Post by: fullheadofnothing on February 19, 2021, 03:43:49 PM
Yikes, the "new" packing room doesn't have tunes?!? I guess I quit the packing racket at the right time.
And for the OP's question: I use Orcas as my living room speakers, for TV, movies, and background music. I also worked in the old packing room for many years. Neither of those systems had/has a sub. I guess I'm missing some stuff, but I don't miss it, if you dig.
Orcas image really well and have a nice clarity. They are quite headphone like, especially in a nearfield setup.
Title: Re: Addicted
Post by: Doc B. on February 20, 2021, 07:20:51 AM
Yeah, I know you would have gone on strike. Difference is you set up the system yourself. Eileen waits for me to do it. And waits.
Actually she cranks up the tunes in her office which is right next door, or I crank the system upstairs. Our neighbor only shows up about twice a week for an hour so we can get pretty obnoxious with the sound levels.
