... would there be any benefit of grid chokes on my old Paramour 1s?Doc B's answer is good. I posted at the same time but it seems lost - I probably neglected to hit the "Post" button ...
Grid chokes pick up magnetic fields and inject the resulting hum voltage directly into the grid, and few if any of them have good magnetic shielding.
Yes you should derive the same benefit from installing a grid choke in a Paramour I as any other cap coupled amp with a grid load resistor.
...Probably a TFA-2004, possibly a Junior (Senior has a 1.75" thick lamination stack; Jr is 1.25"). And probably a BCP-15. You probably got those before we and Mike defined the official upgrades, which are variations based on those two designs (and are among Mikes best work, IHMO).
Edit: I am pretty sure the output is TFA-204 and the choke is the BCP-16. I have the output wired per VoltSeconds suggestion to return it to the top of the cathode bypass cap rather than common.
... Would the improvement be as noticeable in shunt regged direct coupled amps (Paraglow II and Excite)?The advantage of a plate choke, at least in theory, is that it increases the impedance at teh grid of the output tube. The direct coupled amps have no grid resistor, hence that impedance is already infinite and would be hard to increase... :^)
I have not heard of enough examples to have any clear idea about using a grid choke for small signals such as the driver grid. The extra gain after that point would make the magnetic induced hum an even larger problem though.
