Bottlehead Kits => Legacy Kit Products => Stereomour => Topic started by: Filthymidget on December 03, 2010, 11:43:58 AM
Title: Volume level
Post by: Filthymidget on December 03, 2010, 11:43:58 AM
Starting from the 7 o'clock position I've got to turn my volume knob to the 12 o'clock position before i really hear any sound.  Then at 2 o'clock up to 4 o'clock I have high volume.  Is this normal?  I thought I read somewhere that someone turned there's to 9 o'clock and that was plenty loud for them.  I wonder where 0 was for them?  I want my amp to go to 11!!
Title: Re: Volume level
Post by: Jim R. on December 03, 2010, 11:52:32 AM
Wellm, if it were me, I'd be glad to have that much range to play with.  However, nobody can really answer your question without knowing what your source is and what the sensitivity/efficiency of your speakers is.
Post by: Filthymidget on December 03, 2010, 12:24:29 PM
Source is Logitech squeezebox playing flacc and .wav files.  Speakers are 96 db Hammer Dynamics 12's very high efficiency speakers.
Post by: Grainger49 on December 03, 2010, 02:26:26 PM
No volume till 12:00 is not normal or right.
Check your manual where the instructions for the volume control are.  From the picture on the product page the red wires from the selector switch go on the right most lug of the volume pot.  The black wires go on the left most lug of the volume pot.  The cables going to the 12AT7 have the red wires going to the center lug of the volume pot and the black wires to the left most lug of the volume pot.
If that is right you need to check the cables at the selector switch and at the 12AT7 as well.
Post by: Jim R. on December 03, 2010, 04:00:24 PM
Well, if it were me, I'd almost be glad to have that range of control, but given the source and speakers, I'd say something is not quite right.
Did you have your SB modified such that the output op amps were removed and replaced with coupling caps?
This typically brings the output level down to 1vrms.  Also, have you checked to make sure that you don't have the digital volume control turned down on the SB, or maybe in slim server or whatever it is they are calling it these days?
When I had an SB 3, it was modified and had a much lower output level than stock, but I never used the digital volume control because at least mine wasn't a proper dithered control.
I  haven't progressed far enough with the construction of my amp to know what else to suggest at this point.
HTH,
Jim
Post by: InfernoSTi on December 03, 2010, 05:36:46 PM
Not that it is much help, but on my 96db speakers, 7:00 is zero and 9:00 is my normal listening level.  I can actually listen a little lower late in the evening when I need to be a bit quieter.  I don't think I have gone past 12:00 ever....
John
Post by: Filthymidget on December 03, 2010, 05:55:10 PM
Grainger:  All wiring is correct with good solder joints.  Just seems strange to me, it really is weak until i get the knob turned past 12 o'clock then peters out at around 5 o'clock.  It really seems like i'd more power than what is needed but i don't.
Jrebman:  My SB has no modifications done to it.  This volume situation is the same with all input devices.  TV and phono w/preamp.
Post by: InfernoSTi on December 03, 2010, 06:05:35 PM
Have you tried attaching a CD player to it directly via RCAs to see if that is any different?  That might rule out input concerns entirely.
Post by: Filthymidget on December 03, 2010, 06:37:10 PM
Thanks Inferno, i'll try a cd player.  I have a friend with the same speakers but different bottlehead tubeamp.  He doesn't need to go past 3 o'clock position either.  He thought it odd i had this experience.
Post by: Filthymidget on December 04, 2010, 04:13:43 AM
Still low volume level until 12 position.  Could it be a bad volume pot?
Post by: InfernoSTi on December 04, 2010, 08:56:06 AM
Again, I'm probably not knowledgable enough to help, but it seems like you could take some resistance measures at zero, 9:00, 12:00, and 3:00, and full, you could see if you have a "normal" set of readings compared to mine.  Please note I measured twice to get a range since I am only turning to approximate locations. I also only measured one channel (the top one because it was easy to reach) so the range isn't between channels, it is variation in turning to a certain point on the volume.  Here is what my pot measures:
Zero (7:00): 1.6 to 1.7 ohms
9:00: 4.4K to 4.7K ohms
12:00: 14.3K to 14.4K ohms
3:00: 67.7K to 73.6K ohms
Full (5:00): 98.7K to 99.1K ohms
If your measurements are not advancing in a reasonably similar range, that may tell you something.  If nothing else, this gives you something to do this afternoon!
John
EDIT: For clarity, I did this with all speaker wires, RCAs, and power cord removed, as well as the 2A3 tubes removed (I left the 12AT7 in place).  I should have stated this in the post.
Post by: JC on December 04, 2010, 09:00:18 AM
You know, I have to wonder if you maybe just got the wrong kind of pot.  Some type of Linear Taper instead of a Log Taper or Audio Taper.
It is not unheard of that a pot manufacturer lets a few slip out that are mislabeled.
First thing I'd check is the resistance from terminal 1 to terminal three on each section.  Then, the resistance from terminal 2 (the middle) to whichever end is at ground.  Do that one at all of the "o'clocks", and make a note of your readings.
BTW, you may wish to unplug anything you have plugged into the inputs, as the output impedance of another device may interact with the pot and skew your measurements.
Caveat: I don't own your amp or have its schematic, so I'm just going by a general idea of how the pot is usually wired.
EDIT: Hah!  I see InfernoSTi beat me to it!  Note how his measurements are changing in a non-linear fashion!
Post by: Filthymidget on December 04, 2010, 09:53:40 AM
Thanks guys!!  I'll try this afternoon to obtain resistance readings.  I'll post the results after.
Post by: Filthymidget on December 04, 2010, 12:24:12 PM
Ok the first measurements i took were at the pot terminal that has wire going from the potentiometer to the selector switch.
Zero (7:00): 94.4k ohms
9:00: 94.3k ohms
12:00: 94.3 - 94.4K ohms
3:00: 94.1K ohms
Full (5:00): 94.4k ohms
That didn't seem to tell me anything so i took measurements at the terminal that goes from the potentiometer (center terminal) to the power supply.
These were more in line with your readings.
Zero (7:00): 1.4k ohms
9:00: 4.29K ohms
12:00:  12.58K ohms
3:00: 64.1K to 64.3K ohms
Full (5:00): 94.5K ohms
Post by: InfernoSTi on December 04, 2010, 01:19:48 PM
I think the first set of readings shows the full resistance at any position of the control.  The second one is pretty well in-line with what I have in my Stereomour.  It seems that it isn't the pot (or at least not something obvious).
I'm sure Paul Joppa will weigh in the next time he checks the boards....
John
Post by: JC on December 04, 2010, 03:01:03 PM
OK, next I would want to verify a couple of things.  This will be a little redundant, so please bear with me:
1)  Measure resistance from ground to the center pin of the input jack.  Of course, you will have to find the input that is selected by the switch, but presumably the ones that currently aren't selected will read infinity.  When you've found the proper jack, rotate the volume control while observing the reading.
2)  Measure resistance from ground to pin 2 and pin 7 on the 9-pin socket.  Again, rotate the volume control while observing the reading.
Post by: Paul Joppa on December 04, 2010, 04:25:13 PM
Yes, it does sound like the pot is normal. I suspect the operation is also normal.
Nobody actually makes a logarithmic pot - they are a series of linear segments. The inexpensive ones are just two segments - the first half of the rotation is something like 10K-15K linear, from 7:00 to 12:00. The rest of the rotation is a linear 85K segment. So the slope in dB suddenly gets steeper as you pass 12:00, falling to a shallow slope as you approach 5:00. The first hals works the same way, so the last part of the first half (say, 9:30 to 12:00) is a shallow slope, no more than 6dB, while the first part of the second half (12:00 to 2:30) is steeper, maybe 13dB total.
More expensive pots might have three segments, and a few pots made for recording consoles can have even more - but they are quite expensive, comparable to switched attenuators.
Post by: JC on December 04, 2010, 05:11:20 PM
So, then the question reverts to why he doesn't seem to be getting the volume he expects at any setting, correct?
I had been hoping to verify the circuit up to the inputs of the first stage;  after that, I'm pretty much in the dark.
Post by: Filthymidget on December 04, 2010, 05:38:57 PM
My pot is performing the way Joppa describes.  My resistance readings are doing exactly as described.
 I read how others don't find the need to go past 9 o'clock to achieve a good listening level and my friend with the Foreplay stops his at 9 o'clock too with plenty of volume.  I need to have my buddy come over and listen to see what he thinks.  This is my first tube project and i love the sound quality.  I have been listening to these as loud as possible during break in of my new speakers so that might have something to do with it.  Thank you all for the help and suggestions!
Post by: Paul Joppa on December 04, 2010, 06:02:04 PM
 I read how others don't find the need to go past 9 o'clock to achieve a good listening level ...
Yes, that's a sign that the system has way too much gain. 9:00 is at least 20dB down from the maximum, so when that happens you are wasting 3/4 of the available gain. This is extremely common, and a result of the lack of standards. It's a pet peeve of mine, but there's not a lot I can do besides bringing it up as often as I dare to!
Post by: Grainger49 on December 05, 2010, 02:07:14 AM
I'm with PJ, if you only use the pot to 9:00 that isn't optimal.
But to Filthymidget, yes you should with your speakers get loud, louder than you should want to listen to.  I would expect the problem is that your source is not feeding the Stereomour enough voltage.  You checked that with the CD player, maybe.  Just to be sure you might try another source.
Does the SB have a volume control in it?  How far up is that set?
Post by: Filthymidget on December 05, 2010, 06:04:20 AM
I always have the SB at 100% volume control.  I control the volume at the Stereomour.  I'll try another device and see what kind of results I get.  Thanks again.
Post by: 2wo on December 05, 2010, 06:27:27 PM
I have a modified SB and the output is kind of low. try a CD player directly in...John
