Bottlehead Kits => Stereomour II => Topic started by: lesouthern on April 15, 2021, 03:51:58 PM
Hi-
Doing a voltage check.
Getting 0 VDC on 6, 21, 24, 25. All others are normal.
I assume this is a bad solder, outside of the places showing the wrong reading, any suggestions on where else to look?
thanks
-Larry
I would just post build photos. It's very likely that you're missing a connection in order for that to be possible.
found it, was missing L1 -> A2 connection.
thanks
