Bottlehead Kits => Moreplay => Topic started by: TiberKing on February 12, 2022, 06:00:11 AM
Title: Moreplay intermittent static on the left channel. (Solved)
Post by: TiberKing on February 12, 2022, 06:00:11 AM
So I completed my first Bottlehead Moreplay kit a couple weeks ago. It has been wonderful until today. I have noticed static on the left channel. All voltage checks passed, and swapping tubes does not fix the problem. Just curious if there are any common problem areas I should start with before I go too deep. It only seems to show up if the volume is above 9 O’clock on the dial. Thanks in advance for any help with this issue.
Title: Re: Moreplay intermittent static on the left channel.
Post by: Paul Birkeland on February 12, 2022, 06:13:25 AM
I would reflow all of your solder joints.
Post by: TiberKing on February 12, 2022, 06:54:53 AM
That was the ticket! It was the left input RCA jack. thank you so much for the prompt reply!
