Bottlehead Kits => Crack => Topic started by: timmacy941 on January 19, 2023, 10:02:59 PM
Title: Need help with Crack + Speed ball
Post by: timmacy941 on January 19, 2023, 10:02:59 PM
Hi everyone,
I recently build a Crack + speedball, while it sounds great, there is a slight channel imbalance. I have checked on the forum, so far I tried:
- Re-do the resistance check + voltage check, all passed.
- Re-solder all the joints.
- Swapped tubes.
Then I was looking at the resistance between the input RCA and ground, I see that:
- Left: 96K
- Right: 83.5K
Although those are within spec, but it seemed like the channel imbalance could be caused by that, does any one have any other thoughts? Thanks
Some other measurements I read on forum where other people were trying to trouble shoot:
Playing 60Hz on my listening volume:
- Left: 0.58V (AC)
- Right: 0.63V (AC)
Playing 60Hz on max volume:
- Left: 7.15V (AC)
- Right: 7.42V (AC)
Title: Re: Need help with Crack + Speed ball
Post by: Paul Birkeland on January 20, 2023, 04:20:52 AM
- Left: 96K
- Right: 83.5K
From a typical DAC, I would expect 0.009dB of imbalance due to this difference.  Since 1dB is approximately what's an audible difference for most people, this is 100 times smaller than that.
Your source has 7V of output?
If you are only using the first 5-10 degrees of pot rotation, I'd see items #3 and #4 in the Crack FAQ.
https://forum.bottlehead.com/index.php?topic=4295.0 (https://forum.bottlehead.com/index.php?topic=4295.0)
Post by: timmacy941 on January 20, 2023, 06:05:07 PM
Thanks. Right I only use a little bit of the volume range, I will look into adding resistors.
And yes I am using regular DAC, I think the output voltage is 2V.
