Bottlehead Kits => Crack => Topic started by: Exist1214 on May 17, 2023, 05:55:26 AM
I've been having a very odd noise in the audio signal coming from my Crack amp.
I uploaded a .WAV file that I hope accurately shows the problem.
This noise happens when music is playing, when my volume is turned down all the way, and even when my DAC is turned off.
Does anyone have an idea about what is causing this? Thank you!
Edit: The forum does not allow me to upload an audio file. Hopefully this works: https://voca.ro/1dwiE9lyIXAK
Can you tell me about the products you used to build your kit? Solder, flux, etc?
There is a remedy stickied for ground noise from computers and USB powered DACs, but that's not necessarily consistent with the noise I'm hearing from your kit...
I used a 63-37 Sn/Pb solder with a rosin flux core.
I'm not sure where to even start with troubleshooting. I've not had this issue with any other audio devices :-[
Does it happen in both channels? With nothing plugged into the Crack and the volume pot turned all the way down, do you still hear that noise?
What I heard in that noise was a little reminiscent of what I've heard from plumbing flux being used on a build, but it may well end up being USB ground noise or some kind of interference.
Yes, it happens with the volume all the way down and with nothing connected to the amp.
Sorry I missed that - Yes it happens in both channels.
Hmm, just noticed something weird. I issue is normally intermittent...it's not constantly making the noise. Sometimes just for a few seconds, sometimes for minutes at a time.
I found that if I gently pull the smaller tube towards me or push it to the left, the noise immediately comes back. :o
Could this be a bad tube? Bad solder joints? Unfortunately I was thinking that just re-inserting the tube and making sure it's fully seated would fix the issue, but it didn't.
If you tug on both black wires on the headphone jack, is one of them not well captured by solder?
They appear to be pretty well captured by solder
It is very likely that you have a loose solder joint. Wiggling the 12AU7 and hearing the noise change would tend to support that hypothesis as well.
Ok, maybe I'll try to reflow a bunch of the solder joints tonight.
Also try cleaning the tube pins. A scotchbrite pad can do the job.
The pins did not look dirty or oxidized, but figured I'd give it a try before getting out the soldering equipment.
So far so good, thanks! I'll try reflowing the solder joints if it comes back :)
That's the nature of tube pins. They often have a sort of dark finish to them even if clean and, conversely, some can be a little oxidized even if they look very shiny.
I put every tube in a pin straightener as I test them and that is usually enough to clean them up. If they a seem a little suspect once they get in the tester I will usually hit them with a Scotchbright pad and then test them again to be sure they are 100%.
The oxidation can come back fairly quickly depending upon the environment. It's worthwhile cleaning the pins on tubes once a year or more often, just like it helps greatly to clean all interconnect and power cord connections a couple times a year.
Good to know, thanks for the details! :)
I've been running into this same problem again, but I cleaned the pins again about 1.5 weeks ago and the noise has already returned.
Is there something else that could be causing this? Any other tests I can perform to see if the tube is still OK?
Thank you :)
Here’s a tip for cleaning valve pins that is gentle and quick. Stab the tube pins into a Chux Magic Eraser pad a few times. (Can be any brand of magic eraser pad of course!)
Because I own a little yacht that is permanently moored at the coast, I’m never without a product called Deoxit. If I don’t use this stuff, the electronics starts playing up. After cleaning the pins with the magic eraser, spray them with Deoxit and then stab the pins into a second magic eraser pad to remove excess product. Let dry and you’re good to go.
On old vintage tubes the pins are often crusted with a greenish oxide. I find the best way of dealing with that is to stand the tubes in vinegar or citric acid for an hour or two. Then rinse off with water followed by the magic eraser and Deoxit treatment.
Sorry about that - I did not get any notification for your reply.
I will have to try the method you explained above. I don't live in a particularly humid environment and my pins don't have anything that resembles a greenish oxide - they are quite shiny with some tiny scratches after cleaning with a Scotchbrite pad a couple times.
I find Scotchbrite to be very effective, might be time to look elsewhere. If it's as humid as you say maybe there's some crud in the socket. Try inserting and removing the tube 5 times or so and see if you can feel if any of the contacts doesn't feel tight.
Probably a good idea to reflow the socket connections...John
