Bottlehead Kits => Crack => Topic started by: benzxc on June 13, 2023, 11:01:11 AM
Title: Noise in left channel [resolved]
Post by: benzxc on June 13, 2023, 11:01:11 AM
So I've had my crackhead with speedball for quite some time. Recently, the left channel has become noisy, especially when I or the headphone cables move. The left channel would make noises, or sometimes even go silent, from the smallest of movements.
Attached are a few build photos.
Thanks in advance.
Title: Re: Noise in left channel
Post by: Thermioniclife on June 13, 2023, 01:32:35 PM
I would try the headphones on another amp, perhaps the cable is damaged. And it cant hurt to spray a short blast of plastic safe contact cleaner into the headphone jack and plug and unplug the headphones in and out a few times to clean the contacts of oxidation.
Also pull the tubes and clean the pins and a shot of cleaner into the sockets. I use Deoxit D05, it's safe.
Post by: Paul Birkeland on June 13, 2023, 02:09:39 PM
Could I see the wiring at your headphone jack?
Post by: benzxc on June 13, 2023, 11:22:58 PM
Oops! I thought I uploaded the headphone jack wiring - sorry, will upload the correct photograph when I get home.  Appreciate the help!
Post by: benzxc on June 14, 2023, 02:16:36 AM
Here are some photos.
Post by: Paul Birkeland on June 14, 2023, 04:41:22 AM
The joint where the black wires meet may not be completely capturing both black wires.
Post by: benzxc on June 14, 2023, 07:18:31 AM
Perfect, issue fixed! Thanks Paul!
