General Category => General Discussion => Topic started by: Ascari on June 15, 2023, 11:49:25 AM
I am working with Paul to help troubleshoot my Beepre (1) that has lost the left channel. He has been really helpful but it dawned on me that if I could get a replacement board or 2, I could easily just rebuild. Is that something that is available? Of course I, do not expect it for free. I will continue with Paul but thought I would ask. Is this an option, or should I just depopulate the boards?
If you need a C4S board, those are still in production and could be obtained by contacting replacementparts(at)bottlehead(dot)com.
The power supply boards above the transformers are discontinued but I have the leftovers here. For the problem you're experiencing, I would not anticipate you needing to replace the power supply boards.
Thank you Paul. I have the board and parts to fill it on order. Interesting to note when I removed the original board today there was an obvious burn mark that I missed on the smaller (lower powered) transistors. I touched it and it essentially fell apart. At least I can confirm 1 bad part. Since all 4 leds no longer light up, I suspect the other side failed the same way. I will have the parts some time next week and baring any other issues will be back up and running.
