Bottlehead Kits => Mainline => Topic started by: bergurbrag on August 10, 2023, 03:12:06 AM
Title: Intermittend high pitch noise
Post by: bergurbrag on August 10, 2023, 03:12:06 AM
Hi !
I am loving my Mainline amp, but there is a intermittend high pitch noise on the right channel. It comes and goes. It is no a high sound even with the volume turned all up but it is annoying specially when listening to some types of music.
Please help me troubleshoot this issue.
With regards, Bergur Bragason
Title: Re: Intermittend high pitch noise
Post by: Paul Birkeland on August 10, 2023, 05:07:27 AM
Can you describe what the noise sounds like?  If you move the amp to a different room, is it still present?
Post by: bergurbrag on August 10, 2023, 11:35:30 AM
Hi !
Thank you for your most helpful answer. I tried it in another room with another DAC, 300$, and no sound... funny... and again in my listening room connected to my NAD M33, which is an 5000$ unit, I got a little bit more low hum but no high pitch noise. This time I eliminated an extra extension cord.
So mains noise is a real thing, not snake oil
Post by: Paul Birkeland on August 10, 2023, 12:40:03 PM
You could also give this mod a try:
https://forum.bottlehead.com/index.php?topic=11676.0 (https://forum.bottlehead.com/index.php?topic=11676.0)
Post by: bergurbrag on August 11, 2023, 05:16:26 AM
Is this a possible sollution for my Mainline issues ?
See attached photo
Post by: Paul Birkeland on August 11, 2023, 05:22:31 AM
Yes, that's what's in the link that I posted.
Post by: bergurbrag on August 12, 2023, 05:15:57 AM
Hi !
I have done some tests.
Moved the Mainline to another room and connected it to another DAC (Audioquest Dragonfly Cobalt). And no low pitch hum and no intermittent high pitch noise. Then moved it back to my listening room and connected it to my preamp and the hum was back. The high pitch noise seem to be almost gone after eliminating a powerstrip.
Then still in my listening room I connected it to the DAC, the Audioquest Dragonfly Cobalt connected to a Mac. I used the same power connection as when I heard the hum. The hum was gone.
Is this what is called a ground loop noise ? Can it be fixed with a Rca to Rca filter or are there any other solutions ?
Does this mean that adding diodes to the ICE of the Mainline is unnecessary ?
With regards,
Bergur
Post by: Paul Birkeland on August 12, 2023, 05:20:37 AM
I would try the diode modification.
Post by: bergurbrag on August 13, 2023, 04:56:14 AM
Hi!
I am sad to say that the intermittent high pitch noise is back. I tried to run my preamp and Mainline of the same power strip so that they would share the same ground, as someone suggested, but to no avail.
Something new I noticed is that when the Mainline is connected to my preamp through input 1, and playing music and I moved the input switch to nr. 2 I got more high pitch noise and I could hear the music very faintly.
Does this indicate any issues ?
P.s. I have ordered the diodes you suggested.
With regards,
Bergur
Post by: Paul Birkeland on August 13, 2023, 05:20:11 AM
Have you tried the diode modification?
Post by: bergurbrag on August 13, 2023, 05:25:17 AM
Hi !
Here is a photo of the input switch. It seams to me that the connections are ok apart from the fact that I have spilled some solder on one of the pins. The solder reaches one of the metal side plates of the switch. Does this mean that this pin has continuity to ground and should I remove this solder ?
Post by: Paul Birkeland on August 13, 2023, 05:27:18 AM
If that solder touches the metal, you will lose the audio from that channel.
Post by: bergurbrag on August 13, 2023, 06:03:02 AM
Ok, thank you for your reply. I will remove this solder.
But what about that I got more noise and signal bleed?
Post by: bergurbrag on August 14, 2023, 02:40:08 AM
Checked this soldering issue under a magnifying glass.
It is nowhere near the side plate. The angle of the photo doesn’t show it.
Please respond to my earlier question.
With regards,
Bergur
Post by: Paul Birkeland on August 15, 2023, 06:16:36 AM
A little bit of signal bleed isn't necessarily abnormal and isn't a useful piece of information for debugging.  If you put a pair of shorting plugs into the unused pair of RCA jacks or if you hook up a second source that's powered on, the signal bleed will reduce substantially (likely to inaudible levels).
Post by: bergurbrag on August 16, 2023, 04:20:44 AM
Ok, thank you.
I am still waiting on the diodes so I can do the modification to the ICE.
The intermittent high pitch noise in the right channel is still there. It comes on and ends with a short even higher pitch burst. It ends like if you where turning off the water in a sink, a gradual but a short process. As I have said before this noise is not there when use a different source.
Does this tell you anything or is there something I could do to get an answer to why this is happening and what can be done to fix it.
Please help in fixing this issue.
Post by: Paul Birkeland on August 17, 2023, 08:46:39 AM
I think it's likely that the diode modification will solve this issue.
Post by: bergurbrag on August 17, 2023, 09:46:19 AM
Ok, thank you.
Does this modification affect sound quality ?
Post by: Paul Birkeland on August 17, 2023, 09:54:15 AM
No, it just mitigates noise from sources that may have CPU related earth noise issues.
Post by: bergurbrag on August 17, 2023, 10:04:22 AM
Ok, thank you again
Post by: bergurbrag on August 21, 2023, 07:35:30 AM
Did the diode modification and dead silent
Thank you very much for your advice!
Can you be so kind as to explain in a few words how this solution works ?
The amp still has a earth connection ?
I am sending you a picture just to make sure I did it right.
Is it OK ?
Post by: Paul Birkeland on August 23, 2023, 05:39:35 AM
I'm glad that worked out for you.  Some additional information can be found here: https://forum.bottlehead.com/index.php?topic=11676.90 (https://forum.bottlehead.com/index.php?topic=11676.90)
