Bottlehead Kits => Moreplay => Topic started by: AG on September 12, 2023, 03:22:00 AM
Hi to all.
After finished the Moreplay and tested everything work fine.
just curious about the outputs there is a resistor between the outputs. how its works and why not just a bridge, I am missing something?
two outputs are for one amp and headphone amp, thanks for let me know the idea behind of two output.
Cheers from Fla.
Andre.
Those resistors help to isolate the two outputs so they won't interact as much when you have two different devices installed.
Thank you for the quick response!
Cheers from Fla.
Andre.
If you have really long interconnects going to something like a powered subwoofer, putting those after the 220 ohm resistors will provide some isolation between that cable capacitance and the other output of the Moreplay, which is helpful.
Understand. thank you, Paul.
Cheers from Fla.
Andre.
