Bottlehead Kits => Eros Phono => Topic started by: rsmiii on August 19, 2024, 03:42:02 PM
Title: Voltage Check, Issues [resolved]
Post by: rsmiii on August 19, 2024, 03:42:02 PM
Help respectfully requested.
Resistance checks passed beautifully; Tubes light beautifully; LEDs light beautifully like a Christmas Tree.
But voltages on my Eros 2.0 are off, as follows:
IA:  Spec 210-230V – Mine is 222V [OK]
IB:  Spec 210-230V – Mine is 218V [OK]
OA: Spec 155-185V – Mine is 145V [Low]
OB: Spec 155-185V – Mine is 166V [OK]
OC: Spec  95-100V – Mine is 140V [Very High]
OD: Spec 95-100V – Mine is 95V [OK]
OkA: Spec 95-105V – Mine is 140V [Very High]
OkB: Spec 95-105V – Mine is 97V [OK]
OkC: Spec 0.7-2V – Mine is 5.83V [Very High]
OkD: Spec 0.7-2V – Mine is 1.47V [OK]
Title: Re: Voltage Check, Issues
Post by: Paul Birkeland on August 19, 2024, 03:52:03 PM
You'll need to post some build photos.  This can be something as simple as two solder pads on that front C4S board that are accidentally soldered together or a miswire on one of the sockets, or possibly a combination of multiple issues.
I suspect that pins 1 and 2 are touching on your C socket.
Post by: Paul Birkeland on August 20, 2024, 05:15:28 AM
Can I see the bottom of the front C4S board?
Post by: rsmiii on August 20, 2024, 05:37:46 AM
Enclosed, photographs, top & bottom, C4S Board (August 20, 2024)
Post by: Paul Birkeland on August 20, 2024, 05:49:01 AM
The joints circled in red need attention.  At least one of them doesn't look soldered at all.
Post by: rsmiii on August 20, 2024, 05:58:48 AM
Paul Birkeland: Okay, thank you – fingers crossed ... will try later today (August 20, 2024).
Post by: rsmiii on August 20, 2024, 06:32:48 PM
Paul Birkeland: I re-soldered as you suggested, and I am pleased to report complete success.
All Voltage checks perfectly within spec.
Check out this Eros 2.0 playing "Jesus Christ Superstar," attached.
Thank you again for your kindness.
