General Category => General Discussion => Topic started by: hron61 on January 12, 2025, 12:49:12 AM
Title: Hum and tube glowing red on my Foreplay ll
Post by: hron61 on January 12, 2025, 12:49:12 AM
My foreplay ll has been working fine for the past 3-4 months after sleeping for about 21 years.
In the past couple of weeks it has developed a hum on both channels.
Tonight I totally rearranged my stereo system rerouting cables thinking interference from the cables, separated signal cables from ac cables, hooked it back up and hum still there.
But this time when I turned it on still humming I noticed for the first time that my right channel tube is glowing red-hot on top, the left channel seems normal. SEE PICTURE.
I never noticed it before tonight.
Another thing I noticed is if I wave my fingers or hand over the top of the right channel tube without touching it the hum will get louder and when I move my hand away from it the hum goes lower again, weird.
Im not experienced with electronics even though I built it and a seduction and a pair of 300b mono blocks back in 2002-2003, and was a member here back then (same name) but I'm just now getting back into my tube gear.
I used my system for about 1.5 years before they got packed away and the system sounded amazing.
Im hoping it's a minor issue and would appreciate help with figuring out the issue. Thanks.
Title: Re: Hum and tube glowing red on my Foreplay ll
Post by: Paul Joppa on January 12, 2025, 05:19:22 AM
It's not unusual to have different brightness of one or even both section's cathodes like that. You can exchange the two tubes to see if the brightness follows the tube, which is likely. If the hum remains - I expect it will - then it's probably not a bad tube.
The hum may have many causes, but two likely ones are a failed ground connection, or a failed electrolytic capacitor in the power supply. For the former, it is actually pretty easy to re-solder every connection, and it resolves a great majority of problems. It goes faster than you'd think. (Don't re-solder the LEDs or the power switch, they are easily overheated and unlikely to be the problem.)
While you are in there, inspect each capacitor for swelling. And take some pictures of the build and post them. Then do the voltage checks near the end of the manual, and post them as well. That will give us much more information for diagnosis.
Post by: Paul Birkeland on January 12, 2025, 06:44:45 AM
A datapoint worth collecting is to listen to a 60Hz tone and a 120Hz tone, then let us know which one you're hearing out of your Foreplay.
Post by: hron61 on January 12, 2025, 11:24:21 PM
I don't have the tones to listen to just yet but I'll keep looking for some, I'm curious to hear them.
I do have some more pictures and voltages to share. The black strips are pieces of sound dampening.
Can the pictures be resized here before posting them?
I tested all the grounds with my continuity meter and they all beep, I did reflow terminal 14 though which is tied to 13.
I also did the chopstick test on all solder joints the other day while it was playing music and didn't hear any strange noises.
I haven't got around to reflowing all ground connections just yet, only terminal 14 so far.
Also i may add that lately ive noticed the sound has become muffled, like I cant even hear the high hats in the music any longer.
Terminal 2...171vdc,
Terminal 7...159vdc
10/11/12...147vdc,147vdc,147vdc
A1...49vdc
A3...2.09vdc
A4/A5...46vdc
A6...148vdc
A7...49vdc
A8...54vdc
A9...46vdc
B1...55vdc
B3...2.09vdc
B4/B5...45vdc
B6...148vdc
B7...55vdc
B8...58vdc
B9...46vdc
Post by: Paul Birkeland on January 13, 2025, 07:48:49 AM
https://letmegooglethat.com/?q=60hz+tone (https://letmegooglethat.com/?q=60hz+tone)
https://letmegooglethat.com/?q=120hz+tone (https://letmegooglethat.com/?q=120hz+tone)
Post by: hron61 on January 13, 2025, 12:21:05 PM
Thanks Paul.
60hz sound is what im hearing.
Post by: Paul Birkeland on January 13, 2025, 02:16:30 PM
Are terminals 13 and 14 tied together?  Is the earth wire of the power cord connected to the chassis?
Post by: hron61 on January 13, 2025, 10:34:52 PM
Earth ground from power cord is connected to terminal 13.
Terminal 13 and 14 are connected together.
Tonight i reflowed all the ground connections as well.
No changes noticed.
Also tonight i hooked up the adcom gfa5500 ss power amp (that i was using with the foreplay)
to my luxman ss R115 using the adcom as an external amp and had zero issues with the sound or hum. It sounded great. So that leads me to believe it seems to be a pre amp issue?
I did order the 3 nichicon snap in LGR2E221MELA25 caps that posted in my other thread.
S/b here in 2 days.
I forgot to mention that i tightened both tube sockets with a thin dental pic as well tonight.
No changes.
Did you notice any abnormalys with the voltages I posted?
I do appeciate your help very much.
Like i mentioned earlier when i built it it played very nicely, just very little hum and only if i put my ear up to the speaker a few inches away, but that seemed to be the norm from what ive read here without doing a snubber mod.
Ive done no mods other than the c4s, sweet whispers, panasonic caps and the auricaps, which were done as i was building it at the get go.
The ps caps have no swelling or leaking or melted wrappers, no external indicators of failure.
Maybe it is just a cap failure due to their age im guessing and hoping.
Post by: Paul Joppa on January 14, 2025, 04:05:47 AM
The tube socket voltages look right, just as they should be. For completeness you might do the resistance checks as well.
Normally, power supply hum is 120Hz, though failure of soldering of one of the HV rectifier might produce some 60Hz. The effect of your hand affecting  the hum suggests electrostatic pickup, so the level controls are a possible problem area.
There is a possibility that the 0.1uF cap in the power supply has become unsoldered, allowing some hum in the heater power.
That's all I've got right now.
Post by: Paul Birkeland on January 14, 2025, 04:16:28 AM
This feels like a missing earth reference to me.  This comes from the earth lug on your power cord and that is soldered to the chassis.  Back in the day, terminals 13 and 14 weren't connected, and you'd often get hum like this until they were jumpered together.
The hand position influencing hum tends to suggest that you're a better earth than the chassis plate, so maybe use your meter to read DC resistance between the earth pin on the power cord and the chassis plate? (and double check the resistance between 13 and 14 just to be sure).
Post by: hron61 on January 14, 2025, 05:36:43 PM
I measured DC resistance between the earth pin on the power cord and the chassis plate and got 27.3 ohms.
Terminal 13-14 is 3.8 ohms.
One thing i forgot to mention and post and it may be very important is the fact that my outlets are NOT grounded but its plugged into GFCI recepticle. I rent a house built in 1926.
Ive read a gfci outlet should give protection should a fault happen.
One other thing is my power cord is wired with both ends of the cord connected to the ground pins on both ends. Maybe disconnect one end of the ground wire in the cord?
Im not up to speed on on my electrical knowledge but i know a little bit about the safety aspect enough to not get shocked while inside of an amp. I make sure ALL CAPS are discharged prior to parts changing. And keeping a steady hand while testing when energized. And to go slow.
My solid state gear has zero hum, its just the foreplay.
I do have a pair of wl laurel 300b mono blocks that im going recap sometime but im now having second thoughts about using them in this house due to the lack of grounding.
When i built my system back in 2002-3 i was in a house that was properly grounded and everything played well together and sounded great with a tiny bit of hum which seemed normal
without the mods to totally eliminate it.
Post by: Paul Birkeland on January 14, 2025, 06:51:31 PM
Is there anything metal close by in the room you're in or under it?  You could probably grab a proper ground through a water pipe or maybe even a radiator.  This is very likely to be the issue you're up against unless all of this was working in that room previously.
Post by: hron61 on January 14, 2025, 07:57:44 PM
Nope, nothing like that nearby unfortunately.
I do have an idea though, I have buddy that owns a record store in town and sells new and used audio also, I'll call him tomorrow and see if I can bring my foreplay, my ss amp, cd player, my cables and some speakers and hook it up in the shop and see if the hum is still present.
I'm curious to see if it works correctly (no hum) with a proper grounding like when it was first built.
If it does then that should solve the issue unless ive caused damage to it by not having it properly grounded in the first place, which i hope is not the case.
I'll be sure to wave my hand over the tubes as well to see if it makes it hum...maybe im just an
human with special powers I dont know about... Yet.  Lol
Paul Joppa mention the following as well... Thanks Paul  for your help also, much appreciated.
Electrostatic pickup,..Level controls are a possible problem area.
There is a possibility that the 0.1uF cap in the power supply has become unsoldered, allowing some hum in the heater power. I'll check that cap also but I dont know how to check the level controls for problems.
EDIT, i didnt see the 0.1uf cap in there, was it installed in the completely stock unit? Mine is an extended foreplay with no other mods except what was ordered thru Bottlehead.
I do appreciate your time, patience, and expertise in helping me get to the bottom of this issue.
One last thing, the way the treble started to get muffled as well has me baffled as well.
I did read that lowered voltages can have a muffling effect on the sound also, have you heard of that?
Do my voltages seem acceptable?
Post by: Paul Birkeland on January 15, 2025, 05:41:07 AM
I can see your 0.1uF cap in your build.
Muffled treble could be worn down tubes, though your voltages don't exactly indicate that.
Post by: Paul Joppa on January 15, 2025, 06:01:16 AM
The 0.1uF capacitor is located between the right-hand volume control and the adjacent B tube socket - I apologize, I was working from the circuit diagram instead of the physical layout (too lazy to go downstairs and pull out the manual ...).
For the volume control, I was just thinking it might have a bad ground connection or  switch contact. There were two different volume control switches over the years, called "Sweet Whispers" and the later "Sweetest Whispers" - I think you have the first one?
Your voltages are only 7% low, well within normal tolerances.
Post by: hron61 on January 15, 2025, 11:05:33 AM
I see that cap now, i thought it was a type of resistor. Just used to seeing a standard shaped cap.
I'll reflow that one also as i only checked for a loose connection on it earlier.
I'm curious now about the sweet or sweetest whispers, since i dont have my original paperwork from when i purchased the foreplay, i'll research it further for external indentifiers of each. I'll post a seperate thread for that info.
Post by: hron61 on January 15, 2025, 09:02:33 PM
The 3 power supply caps arrived today and got them installed.
Will power up tomrw and check voltages and resistance and if all goes well i'll fire it up and see if anything changes and report back. I'll order that .1uf cap that I overlooked asap too.
Post by: hron61 on January 15, 2025, 11:28:49 PM
I'm pretty sure i have the Sweet Whispers. I bought the fp in 2003 but i do remember the manual said rev2. All my paperwork and manuals were lost back in 2004
I found an old post that said the Sweetest Whispers were used in Foreplay lll.
Btw, would you have replacement recommendation for the 0.1 cap? I've been searching and so many choices and i just want to make sure i get a correct replacement. Much appreciated.
Post by: Paul Joppa on January 16, 2025, 03:39:33 AM
The 0.1uF cap should be rated for at least 100 volts. (The original is "400v, metal film"s. It, along with the two resistors to which it is connected, raises the filament power bias voltage to around 45-50 volts. It is NOT in the audio circuit, so nothing critical. It is unlikely to be a problem unless it is incompletely soldered, so re-soldering it probably sufficient. It and the two resistors are all crammed into the pin 9 solder lug of the B tube - it's a tight fit, which is a risk factor in making good solder joints.
Post by: Paul Birkeland on January 16, 2025, 12:55:21 PM
Leave the one you have in place.  Those things are extremely long lived.
Post by: hron61 on January 16, 2025, 02:38:43 PM
Thanks for the info on what the 0.1 cap is for.
And solid advice from both of you about it, thanks for that.
It is very tight in there and i do have continuity in the connections of it and the solder doesnt look cold, so i'll just let it be. Dont want to create an issue if its not an issue.
Post by: hron61 on January 19, 2025, 11:06:26 PM
I thought i would post a quick update on the situation and to thank you for trying to help figure this out for/with me.
I havent tried hooking the system up to a grounded electrical outlet just yet, i ordered resistors to make a shorting plug for the fp outputs and waiting for those. I would like to check the hum level.
A quick history note...when first built back in 2003 with the extended version installed at the get go
it was hooked up to my WL Laurel 300b mb with Klipsch Forte's and a Thornes turntable with diy cables of belden 89259 ic and belden 89364 for the pc and the hum was barely noticeable and only and only if i put me ear within a couple of inches from the speaker BUT it was plugged into a properly grounded electrical system. Everything played very well with each other and sounded amazing, then packed away.
Fast forward to today 22 years later and just the foreplay is being used Without a grounded outlet.
Its hooked to a solid state adcom gfa5500.
I did hook it to another adcom amp i own, a ss gfa535 and got the same hum as the with the 5500 amp.
Another thing i did was used my Luxman ss R115 receiver as a pre and hooked it up the 5500 and got Zero hum, quiet as a mouse.
I installed new power supply caps in the foreplay, reflowed all ground connections, did the chop stick testing., and tried multiple tubes and hum is still there.
Im not into electronics like alot of members here but i can follow directions in laymans terms and can solder very well.
Im still waiting to bring the system to my buddy's store to hook it up to a grounded outlet, im hoping that it just needs to be grounded.
For safety sake the Foreplay and the Adcom are plugged into a GFCI ext cord while im using it.
I'll post back after the hum is measured and i hook it to ground which should be soon i hope.
In the meantime feel free to toss anything else out there, im all ears and appreciate the help.
Post by: Paul Joppa on January 20, 2025, 03:19:35 AM
This is a real puzzler!
I still suspect a ground problem, but a grounded outlet could easily be a red herring. It's not much help, but as I recall those copper ground wires were a real bear to solder - the insulation was extremely hard to get through or burn off. And terminal 14 seems to have a bunch of them, which makes it even harder. It would not surprise me if a connection failed there.
Post by: hron61 on January 20, 2025, 11:47:54 AM
Yes, it sure is.
Thats funny that you mentioned terminal 14 ground.
Late last night i was thinking the same thing.
I will put great effort in totally reworking all connections on that area.
Last night i watched some soldering videos on this sight that doc(thanks doc) had posted years back and it got me thinking about a good mechanical connection before the solder is applied and proper wire stripping, how very important that combination is.
One of the videos showed just how important flux is for the metal. A very eye opening matter to say the least. Oxidation of the metal must be eliminated.
I also use the Cardas Quad Eutectic Solder and have a container of their flux that I will make sure to use on that area as well.
Post by: Doc B. on January 20, 2025, 05:28:22 PM
There is plenty of flux in the core of the Cardas solder. Don't add extra. That will make things worse.
Post by: hron61 on January 22, 2025, 12:25:21 AM
Hi Doc,
Thanks for the tip.
Definitely don't want to make it worse.  ;)
Post by: hron61 on February 01, 2025, 07:50:47 PM
Heres an update on the hum issue ive been trying to locate.
Took the advice from Paul to fully check over all my solder joints including terminal 14 which is very busy indeed. I completely desoldered term 14 and made sure all wire ends had no varnish on them, i rescraped all the ends with an exacto knife also.
Before i resoldered the wires i moved a couple to the eyelet below the top hole of same 14 terminal and that took away the clump of wires, and made for a better connection for ground.
While searching for questionable solder joints i found one on a right channel rca center pin and repaired that. Still hums but very slightly less but nothing to write home about.
I still havent tried hooking up system to another location with a grounded electrical system just yet
but will do that soon.
The main amp is an Adcom gfa 5500 and i also have an Adcom gfa 535mkl which i hooked up also and it hums too. I did check bias and dc offset and adjusted to factory specs on both also.
I must say, the little Adcom gfa535mkl is one sweet sounding little amp and was worth every penny of 49.99. Lol
Ok so now heres where it gets weird, i also have a Luxman R115 ss receiver in mint condition and sounds wonderful. On a whim i connected the foreplay to the tape in of the luxman to use it as the pre, then i hooked up the gfa535 to the pre outs of the luxman to use that as the power amp.
So basically the luxman is just the middleman AND it has a remote (nice).
When i turned everything on i have very very little hum. Weird huh? And that motley crew acually sounds pretty good together.
So im thinking it must some sort of ground loop issue afterall because when i first built it back in 2003
i didnt have a hum whatsoever, (and with a properly grounded wiring system)... just a deep dark silence. Even the seduction i built with it had zero hum.
Its strange that by hooking everthing up to the Luxman thats what took the hum away.
Since this home has no ground in the wiring the pre, receiver amd main amp are plugged into a GFCI heavy duty cord. The rest of the stuff all plugs into an older monster cable 2500 power station component.
Man as im in my mid sixtees now,i do love that remote, lol.
I still want to measure the hum since i got a couple of output shorting jacks with resistors made up finally.
So what do you think about this?
Post by: Paul Joppa on February 02, 2025, 03:57:59 AM
I think you are right, it's a "ground loop." (I put that in quotes because most ground-current issues are noise capacitivly coupled from power transformer windings, rather than magnetic fields.)
I haven't had my coffee yet this morning, so I 'll have to think this through before I have any advice to offer.
Post by: Paul Birkeland on February 02, 2025, 06:12:44 AM
Do you have any water pipes or gas pipes near your system?  Is your gear plugged into an outlet on an exterior wall?
While it is a tremendous pain in the butt to add grounds to all the outlet in a house, it can be very easy to add a ground to just one outlet.
Post by: hron61 on February 20, 2025, 01:49:04 AM
Sorry for the delay in response, i just havent had anything positive to add unfortunately.
Been reading many many posts going back years and trying to gather info from others to print out and research. There are so many possibilities and I've tried many but no luck so far.
Have gone over all the solder joints with my magnifying glass, refrowing all joints,qmaking sure the wires are routed correctly, etc.
My next step is to measure the hum then to bring the system to a friends house with proper grounding. I do believe that to be the problem because I have not touched the underside at all since it was built in 2003 and it was in a home with a proper ground and it was quiet then.
I built a Seduction pre and a pair of 300b's around the same time and they was quiet as well.
I know that when turn off the amplifier the hum goes away, does that sound like a grounding problem? Or an impedance issue? It does it with all 3 amps I've tried.
No luck on the wall, its an interior directly in center of house.
Post by: Thermioniclife on February 20, 2025, 03:37:40 AM
You can buy a 2 prong male that has 3 prong female they have a short green wire with a fork connector that you loosen the wall plate mounting screw, slip the fork under the screw and retighten thusly giving a ground to the 3 prong female. there cheap. There sometimes called cheater plugs.
Post by: Paul Joppa on February 20, 2025, 04:12:43 AM
I don't recall seeing in this thread the question "are all the components plugged into the same outlet?"
If not, give that a try.
Post by: Paul Birkeland on February 20, 2025, 04:32:08 AM
Post by: hron61 on February 20, 2025, 11:01:52 PM
Only one outlet is used. Foreplay and amp are plugged into a gfci extension and the cd player is hooked up to a monster cable hts 2500 power conditioner.
TV, soundbar, and cable box,  security system touchpad, and 2 subwoofers are also hooked into the monster conditioner as well.
I tried the cheater plug early on with no luck. Outlets are ungrounded, house is 96 years old.
No water pipes nearby, outlet is mounted to a center interior wall unfortunately.
Post by: Paul Birkeland on February 21, 2025, 05:33:19 AM
Do you own this house, or is it a rental?  Where the outlet is, do you have access below it?
If you have a basement below that's relatively open (typical for older houses), it may not be the end of the world to run a ground wire for just that outlet.  Even if it doesn't end up resolving your issue, it's a very good idea to do this anyway.
