Bottlehead Kits => Eros Phono => Topic started by: Henry2011 on August 07, 2011, 09:07:55 AM
Title: Eros Phono kit is in transit - any capacitor upgrades?
Post by: Henry2011 on August 07, 2011, 09:07:55 AM
Some of us have Eros Phono kits in transit.  I would like to do any recommended capacitor upgrades during the initial build (as I did with my SEX amp).  What capacitor (or other component) upgrades have proven worthwhile in the Eros Phono?  Are there any other mods to the Eros Phono that have shown a performance improvement?
My phono cartridges are relatively high output Grado moving iron (in the 4mv to 5mv) range so I am not considering SUT installation.  The Eros output will go to my SEX amp input.
Title: Re: Eros Phono kit is in transit - any capacitor upgrades?
Post by: Grainger49 on August 07, 2011, 01:55:24 PM
The high voltage supply is regulated and isolated with a C4S.  The heater supply is regulated as well.  The most important capacitor in the circuit is the output capacitor.  The output stage is designed around the Seduction final stage.  PJ has said that a 0.47uF was the design value.  0.47 in this position will cover all audible low frequencies.  The 1.0uF that is supplied with the kit is an upgrade; not because of the increased value but because it is a PP film cap, better sounding.
I was musing online with Paully about the use of two 0.22uF 600V KK Teflons (in parallel to achieve 0.44uF) there.  This is the largest value I could find in a 600V KK Teflon cap.  These caps are very nice sounding and unusually inexpensive.  PJ urged Paully to try just one 0.22uF at first.  The indication was that a second might not bring any additional bass information to the table at all.  Bass is what is sacrificed with a lower value at this point of the circuit, nothing else.
Edit: I tried one 0.22uF and two 0.22uF caps in parallel.  I preferred the single 0.22uF cap.  There was no audible loss of low end.
So my obvious suggestion is for you to buy some of these, break them in as I have posted and report back.
Post by: Henry2011 on August 07, 2011, 04:51:37 PM
Grainger,
Thanks for the info (especially the link to cap break-in techniques).
Henry Moore
Post by: Anton on September 30, 2012, 09:38:20 AM
Hello,
I was wondering if anybody tried these capacitors with the Eros
http://www.v-cap.com/teflon-capacitors.php
http://www.v-cap.com/copper-teflon-capacitors.php
I was looking at 0.47uF 600V caps there - but they are pretty expensive.
Right now I am using soviet military Teflon caps 0.22 uF 600V (thanks to Grainger for recommending me those). Soviet caps sound beautiful, especially considering the price. Prices on V-cap are quite high and I was wondering if the sound improvement will be great enough to justify the price? Or is it just a waste of money?
I would appreciate any feedback/opinion on this.
Thank you
Anton
Post by: Paul Birkeland on September 30, 2012, 09:43:40 AM
The coupling caps in the stock kit are 1.0uF Solens (though we may have shipped you 1.5uF's in their place).  This would be the most significant upgrade, and you could easily go much lower than 1.0uF, .47uF is a decent choice.
There's also a 0.1uf cap in the shunt regulator circuit that's potentially worth upgrading.  A 400V cap is OK here.
The 75K 1/2W and and 47K 2W resistors are also very much in the signal path, those could be upgraded, but be sure to use 1% parts or buy enough to match.
The 10.5k resistor, 0.030uF, and 0.010uF caps make up the RIAA network, you can find decent upgrades for those at Parts Connexion, but again, keep the resistors as 1% parts, caps at no more than 3% unless you can find a pair that measures closely.  For the 0.030uf cap, paralleling two 0.015uf caps tends to be easier to implement than finding a 0.030uf.
Post by: Anton on September 30, 2012, 11:33:50 AM
Paul,
Thanks for your response. Yes you are right - I had 1.0 uF 630V caps with my Eros.
I replaced those with 0.22 uF 600V teflon capacitors. I noticed an improvement.
I guess what I really was asking - if anybody tried those V-cap Teflon capacitors I mentioned above
and if it worth to upgrade considering their price.
Thank you for other recommendations too.
Anton
Post by: Paul Birkeland on September 30, 2012, 02:08:03 PM
I have V-caps in my personal Tube Phono, they take a long, long time to break in, but are well worth it, especially in a circuit as well designed as the Eros.
Post by: Hank Murrow on September 30, 2012, 03:05:05 PM
Check out these pages:  http://www.v-cap.com/hank-murrow.php   &   http://www.v-cap.com/bottlehead.php
For a Custom Bottlehead system using V-caps throughout.
Cheers, Hank
Post by: johnsonad on September 30, 2012, 03:16:58 PM
As the output caps or in the RIAA?  If output caps, what size are they?  My tube phone has v-caps in the RIAA but Auricaps in the output.
Post by: Paul Birkeland on September 30, 2012, 06:52:54 PM
Coupling only, the typical tolerance on the V-caps isn't quite tight enough for RIAA use, though you can always e-mail Chris and ask about getting a pair matched close to your intended values.
Post by: johnsonad on September 30, 2012, 09:03:02 PM
PB, I have Dan's old Tube Phono (which you built correct?).  It looks to have V-Caps in the RIAA but Auricaps as coupling caps. It sounds great but I would be willing to upgrade the coupling caps if it might make an improvement. What value would you recommend?
Post by: Paul Joppa on October 01, 2012, 05:18:04 PM
A quick note - I chose 0.01uF and 0.03uF for the Eros (Seduction has 0.033 and a paralleled combination of 0.01 and 0.0012 for net 0.0112) partly because exotic capacitors are often not available in all values, but 0.01 is always available, and you can parallel three of them to get 0.03. And this way you can buy ten of them to get a price break, with only two left over. If you have a capacitance meter, you can sort them for the best matches.
I've never done this, but the possibility is built into the design on purpose  :^)  However, you are on your own finding a way to fit them in!
Post by: Hank Murrow on October 02, 2012, 08:37:44 AM
The ever thoughtful PJ again offers a smooth path to upgrades!  Cheers, Hank
Post by: mwaller on May 14, 2016, 10:11:04 AM
Would a precisely matched pair if 0.033uf caps work in the RIAA circuit in lieu of the .030?  Is there a way to adjust the R value to accommodate this?
Thanks,Mika
Post by: Paul Joppa on May 14, 2016, 11:11:08 AM
Yes it can in theory be done, but you'd have to calculate the value, and replace, several other components. The calculations are not exactly trivial.
Post by: Paul Birkeland on May 16, 2016, 06:49:10 AM
If you want to use .033uF cap, you'll have to change:
75K resistor to 72.2K
0.01uF cap to 0.0104uF
The 10.5K resistor can stay.
After making these changes, you'll want to measure RIAA accuracy to be 100% sure that the component values are agreeing with the calculations.
To be fair, there are $10,000+ phono preamps on the market that use the exact same caps in the RIAA eq.
Post by: Paul Joppa on May 16, 2016, 10:15:15 AM
By my calculations, the following changes are necessary (nearest standard 1% resistor in parentheses):
75K becomes 68.7K (use 68.1K)
0.030uF becomes 0.033uF
10.5K becomes 9636 ohms (use 9530 or 9760)
0.010uF becomes 0.0113uF
301 ohms on the C4S feeding the plate  becomes 288.5 (use 287)
Post by: Paul Birkeland on May 17, 2016, 07:01:30 AM
Forgot about adjusting that one!
Post by: mwaller on May 17, 2016, 11:25:41 AM
I really appreciate the input. I think that is more work that I am interested in...
I have two v-caps that measure .009840 uF and .009843 uF.  Are these going to be sufficiently close to 0.010 to work in the "stock" RIAA network?
I seem to recall reading that the "ideal" value is actually just a bit above 0.010, which has me a bit concerned...
Mika
Post by: Paul Joppa on May 17, 2016, 01:32:54 PM
The theoretical ideal second cap is 0.010288uF, but the 6922 input Miller capacitance is around 50pF. the wiring probably adds another 10pF, so the target should be 0.010228. Subtracting the measured v-caps gives a residual of 388pF, the closest standard value is 390pF. That leaves you with a ~4% error - not big but possibly audible under some circumstances. Why not pick up a couple and bypass the V-caps?
Ceramic caps are crap for audio, with the exception of Type C0G or NPO which are said to be excellent; their main problem is that only very small values are available. 390pF is very small, and since it is dominated by the v-cap, you do not need precision in the bypass. For small values like this, mica and polystyrene are widely likes as well.
Post by: mwaller on May 17, 2016, 01:39:12 PM
Excellent info, thanks! I'll look for a suitable bypass to bring me closer to ideal.
Can you tell me what the ideal value is for the 0.030 cap?  I've been offered a pair of V-caps around .03125, but I'm guessing they are too big. Thoughts?
Thanks again!
Mika
Post by: Doc B. on May 17, 2016, 02:18:38 PM
The flaw in this deal is that you guys are perplexing over picofarads, but you aren't talking about measuring the preamp's response when you are done changing everything. What matters is that the preamp faithfully reproduces the RIAA curve, even over the precision of the value of the cap based upon theory. The value that keeps you within, say, 1/2 or 1/4 dB of the established curve is the correct value, even if it deviates a bit from the theoretical value. If you look at the notion of improving the preamp with these mods that way, the best resistors for the eq circuit will then be trimmers.
That said, our preamps are designed to be pretty faithful to the RIAA curve with the stock components.
Post by: mwaller on May 17, 2016, 02:50:58 PM
My goal in pursuing these mods is not to improve RIAA accuracy over stock.  Rather, I'd like to squeeze the last bit of resolution out of this great circuit without harming the RIAA performance.  I would love to measure performance if I had the tools and knowhow, but I don't.  As best I can, I want to stick to the stock theoretical values since they sound great to my ears!  I'm going with 0.1% foil resistors, so uncertainty in those values will be reduced by an order of magnitude.  Thanks,Mika
Post by: mwaller on May 18, 2016, 06:13:51 AM
Hi Paul -
Is 0.03125uF too far out for the 0.030uF caps in the RIAA network?
Mika
Post by: galyons on May 18, 2016, 07:21:46 AM
Hi Paul -
Mika
Is that the nominal labeled value or the measured value?  When dealing with RIAA EQ, I always measure the capacitance and use that value.
Geary
Post by: mwaller on May 18, 2016, 08:17:26 AM
Geary
0.03125uF is the measured value.  Thanks!
Mika
Post by: Paul Joppa on May 18, 2016, 01:47:47 PM
It's further out than I would like, but probably acceptable to most people.
Post by: mwaller on May 18, 2016, 04:19:44 PM
What value is ideal per the model?
Thanks, Mika
Post by: Paul Joppa on May 18, 2016, 07:21:06 PM
Thanks, Mika
0.030uF.
Post by: mwaller on June 21, 2016, 07:49:13 AM
So, I finally got around to installing some new parts in my Eros...
I replaced the output caps with V-Cap CuTF.  In the RIAA network, I replaced the 0.01uf with selected pair of V-Cap TFTF caps and the 0.03uf with a selected pair of AudioCap RT (polystyrene).   I also replaced the 47K input load and EF86 plate load resistors with Texas Components TX2575 "naked" foil resistors.  Sounds great!
I'm noticing that the power transformer and aluminum chassis of the Eros get quite warm after a hour or so - almost too hot to touch. Is this normal?  It's been so long since I listened to vinyl that I can't remember how it was before the mods...
Mika
Post by: Paul Birkeland on June 27, 2016, 05:32:46 PM
The tubes get nice and toasty, especially the 12BH7, as does the transformer.  Consequently, the plate will be quite warm to the touch after it's been on for a while.
Post by: JamieMcC on August 20, 2016, 12:58:04 PM
I'm looking ahead a bit here and am after a few pointers on favourite resistor brands for maybe later swapping out the stock 75K 1/2W and 47K 2W resistors  ::)
I have liked the results of using the Vishay Dale RN series in the past for building attenuators but wondered what other makes you guys have been using.
TIA
Post by: Sjaakhuijsman on December 28, 2016, 05:48:07 AM
Hello people :)
Here goes my first post.....reviving a cold topic  ::)
I am waiting for my Eros phono and I read about the 0,47 uF cap, but I can't find it in the manual (parts list).
I find 0,01 and 0,03 uF for RIAA correction, 0,1 uF.....1,0uF.....1,5uF......10uF and so on.
What am I missing?
Greetings from Amsterdam
Post by: Tom-s on December 28, 2016, 06:30:44 AM
See post #2 (http://bottlehead.com/smf/index.php?topic=2017.msg15573#msg15573) in this thread for the answer. Nice to see more Dutch Bottlehead fanatics.
Post by: Sjaakhuijsman on December 28, 2016, 11:43:07 AM
Thanx Tom! Very kind of you.
That would be the three 1uF ceramic capacitors of 50V used at the C socket.
I Can't see other 1uF capacitors used.
Am I right?
Post by: Sjaakhuijsman on December 28, 2016, 11:53:31 AM
Ah...there is some difference between parts list (1,5uF 630V film cap) and the manual (picture) with 1,0uF MKP film cap....
Post by: Paul Birkeland on December 29, 2016, 09:32:39 AM
Yes, we consolidated and send the kit with a 1.5uF cap instead of the 1.0uF cap.  There is electrically no difference in the Eros circuit between the parts.
