Bottlehead Kits => Eros Phono => Topic started by: Grainger49 on April 20, 2012, 09:22:58 AM
Title: Eros Output Caps
Post by: Grainger49 on April 20, 2012, 09:22:58 AM
Long before ordering an Eros, maybe 2 years before, I ordered and broke in 4- 0.22uF 600V KK Teflon caps.  The design output cap for Eros is 0.47uF so 0.44, a pair in parallel, is close enough not to make a bit of difference.  In the thread where Paully and I discussed this possibility Paul Joppa suggested that I try one 0.22uF per channel at first.  The thought being that there would not be an audible difference in the bass extension in most rooms and systems.
I PMd Paul Joppa today to tell him he was right.  I also emailed Paully.  He also has a quad of the KK Teflons.
I finally started to tweak my Eros after 5 months.  I just didn't want to remove it from my system to make modifications.
Here is the bottom line on the KKs.  They have an obviously improved presence, more "body" in the body (can I copyright that phrase?), over the stock Solen caps.  They have a smoother, maybe more extended highs.  Transients are improved.  And two of them per channel seems to smear the image a little so I'm listening to one per channel.
A quick and dirty run down, the 0.22uF 600V KK Teflon is an improvement.  I challenge you to hear an improvement in your bass end with two of them per channel.  Our rooms and system response, well most of ours, is not enough to show the improvement.
The next step is to insert the already burned in (3 weeks) Mundorf Silver/Gold/Oil caps. (pause while I swap and listen)
Makes you think when swapping alligator clip jumpers on a 400V circuit.  Well, makes me think, I have a pacemaker.
The Mundorf are more relaxed (and more recently broken in, that might matter, might not).  The picks on strings are more present and apparent.  The flutes now have wood around them (listening to El Condor Pasa and the flutes in Urubamba are wooden flutes).  Bass is extremely tight (this is the remastered Japanese pressing I received recently).
So Long Frank Lloyd Wright is so realistic you can see what color shirt Paul is wearing.  This is another improvement in the midrange.  I couldn't pass up the possibility to get these when Parts ConneXion put them on sale recently.
So with this cap, you do get what you pay for.  But the KK Teflons are cheap and beat out many caps under $40 each.
Just for yucks I put in some KK PIO 2.2uF 400V caps.  I bought a bunch of them several years ago.  They are awfully good for the price!  These were awaiting installation in my second set of Minimus 7 crossovers.  They are parallel combinations of 2.2uF caps, so they are 4.4uF.  There was no increase in bass over the 0.22uF KK Teflon.  But they are surprisingly good sounding.  Definitely better for me than the stock Solen.  The stock Solen is not a bad cap by any measure.
Here is a link to some similar KK PIO for anyone who wants to fool around with KK PIO caps (link changed to K75-10 PIO):
http://www.ebay.com/itm/260995030413?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
BTW, there is no way for me to go back to the Solens.  I removed the first one in the listening room and can't find it any more.
Some time in the next year I might stumble across it.  Things go into some black hole that doesn't spit them out for months in my house.  Yours might be the same.
Edit: I found it.  It wasn't there before so it came back through the black hole today.
Title: Re: Eros Output Caps
Post by: galyons on April 20, 2012, 10:52:24 AM
Hi Grainger!
I am a little confused.  The eBay link is to Russian K42's which are metalized polypropylene in oil. (Very similar the the Mundorfs).  There is a Russian 0.22uf 600v Teflon cap, it is an FT3. They sound divine! They are rather huge by comparison to the K42's.
You might want to also try Russian k40Y9, .You can find them in .22,.33 and .47uf as well as 200V, 400V and 630V. The K40's are aluminum film with paper in oil.  Though the K40's are getting more scarce.  The K40 is the "gold standard" of Russian PIO's more like Vitamin Q's, just a bit more detailed.
Geary
Post by: Grainger49 on April 20, 2012, 11:41:47 AM
Yup, mine that are playing now say K75-24.  The title of the ebay auction says "0.22 uF 500 V PIO Capacitors K42Y-2" which made me think they were Paper In Oil (PIO), since the title says so.  I changed the link to some K75-10 PIO.
Some other information I have gathered says a K75 with no other numbers is Polypropylene in oil.  But K75-10, -15, -17, -24, -25 and -28 are "PIO" caps.  I am thinking it is paper not polypropylene in oil.  The page I'm looking at mentions a K42U-2, the only K42, and calls it a PIO.
I have listened to some old Vitamin Q caps, they didn't float my boat.  They also could have been damaged too.
The KK Teflon caps in the OP are FT-3 and are 4 times the size of the stock Solen PP Film caps.  See the picture below.
Post by: Grainger49 on April 20, 2012, 11:51:03 AM
I found the lost Solen taken out this week.  Comparing to the  that were playing the Solen is not as clear in the mids and highs.  The violins lose the resinous character they had with the KK caps.  The KK K75-24 would be a great first step up for anyone with an Eros.
Post by: Roger on April 20, 2012, 11:57:23 AM
Long before ordering an Eros, maybe 2 years before, I ordered and broke in 4 0.22uF 600V KK Teflon caps.  The design output is 0.47uF so 0.44 for a pair in parallel is close enough not to make a bit of difference.  In the thread where I figured this out Paul Joppa suggested that I try one 0.22uF at first.  The thought being that there would not be an audible difference in the bass extension.
I PMd Paul today to tell him he was right.  I also emailed Paully.  He has a quad of the KK Teflons.
I finally started to tweak my Eros after 5 months of not wanting to remove it from my system.
Here is the bottom line on the KKs.  They have an obviously improved presence, more "body" in the body, over the Solen caps.  They have a smoother, maybe more extended highs.  Transients are improved.  And two of them per channel seems to smear the image a little so I'm listening to one per channel.
Quick and dirty the 0.22uF 600V KK Teflon is an improvement and I challenge you to hear an improvement in your bass end with two of them per channel.
The Mundorf are more relaxed.  The picks on strings are more present and apparent.  The flutes now have wood around them (listening to El Condor Pasa).  Bass is extremely tight (this is the remastered Japanese pressing I received recently).
So Long Frank Lloyd Wright is so realistic you can see what color shirts they are wearing.  This is another improvement in the midrange.  I couldn't pass up the possibility to get these when Parts ConneXion put them on sale recently.
So with this cap, you do get what you pay for.  But the KK Teflons are cheap and beat out many caps under $50 each.
BTW, there is no way for me to go back to the Solens.  I removed the first one in the listening room and can't find it any more.  Some time in the next year I might stumble across it.  Things go into some black hole that doesn't spit them out for months in my house.  Yours might be the same.
Just for yucks I put in some KK PIO 2.2uF 500V caps.  I bought a bunch of them several years ago.  They are awfully good!  Excellent in pairs for Minimus 7 crossovers.
Here is a link to those for anyone who wants to fool around with caps:
http://www.ebay.com/itm/0-22-uF-500-V-PIO-Capacitors-K42Y-2-Set-of-30-New-/310389100773?pt=LH_DefaultDomain_0&hash=item4844a1d0e5
Have you tried the Mundorf Silver/oil. Personally I prefer those to most other caps, and cheaper.
Roger
Post by: Grainger49 on April 20, 2012, 12:21:48 PM
Roger,
I believe that, Silver/Oil, is what is in my FP 2 now.  I went with S/G/O because of the high discount of the sale.
Are you saying you have tried Silver/Gold/Oil and prefer the Silver/Oil?
Post by: galyons on April 20, 2012, 12:50:12 PM
Yup, mine that are playing now say K75-24.  The title of the ebay auction says "0.22 uF 500 V PIO Capacitors K42Y-2" which made me think they were Paper In Oil (PIO), since the title says so.  Some other information I have gathered says a K75 with no other numbers is Polypropylene in oil.  But K75-10, -15, -17, -25 and -28 are "PIO" caps.  I am thinking it is paper not polypropylene in oil.  The page I'm looking at only mentions a K42U-2. And calls it a PIO.
I have listened to some old Vitamin Q caps, they didn't float my boat.  They could have been damaged too.
Yes, I know it is confusing.  "PIO" sells caps, whether or not they are strictly "Paper in Oil", well caveat emptor!  I have been building/rebuilding/modding tube amps & preamps for years.  There is very little out there in caps that can beat the Russian caps for sonics and build quality.  The caps that get somewhat close carry hefty price tags. Unfortunately, often those hefty price tags reflect marketing rather than value!! The old audiophilia nervousa, if it costs more it MUST be better!!
Geary
Post by: Noskipallwd on April 20, 2012, 06:09:06 PM
Glad you finally got a fix for those cap cravings Grainger. Cap withdrawls can be a B***h. Interesting about the russian caps, glad they are working well. As far as the Mundorf S/Os vs. S/O/Gs, I have only had one chance to listen critically to both types in the same circuit. To my ears there is a small difference, so minute that I can't define exactly what that difference was, I preferred the S/Os though. However, the sound signature quality that you deem most important, (soundstage), was virtually identical between the two cap types to my ears. Slightly off topic, I listened to some metal today through the Eros, System of A Down, 'Toxicity' through tubes and full-range drivers. Very interesting.
Shawn
Post by: Grainger49 on April 21, 2012, 01:54:29 AM
Shawn,
I guess the comparison shows the depth of my depravity.  At first I intended to replace the Solen with the KK Teflons.  Then the cap sale came to my attention and I bought the Mundorfs.  The KK "PIO" were just sitting on the work table, so late in the day they came upstairs to see if they were at all worthy of the Eros.  Never mind the drawers and drawers of capacitors still down there that I didn't drag upstairs.
My first thought was to use the Teflon because of the excellent, clear, present Teflon sound.  It adds a clarity other caps don't have.  The midrange is tactile with Teflon.  But then the sale came along and since I have been very happy with the Mundorfs in my FP 2 I went for S/G/O.
The biggest surprise was how good the cheap KK PIO sounded.  I bought 20 of them about 8 years ago for ~$15 delivered.  The prices have gone up.  Today you can get 4 for ~$21 delivered.  They have been discovered, no more secrets.
Whether you listen to metal or string quartets a sweet sounding tubed system can really make a difference.  If tubes didn't make a difference all the best guitar players would be using solid state amps, and they are not.
Edit: Just to show how bad my obsession is, I looked through some of the drawers filled with caps including some Wonder Caps from years long gone.  For some reason I have a new, single 1.5uF 630V Solen and a new, single 20uF 400V Solen.  I don't know why I bought them or what they were for.  I usually buy in pairs or more.
Post by: Noskipallwd on April 21, 2012, 03:33:42 AM
Grainger, what value are the PIOs, they get big pretty fast as you go up in value. Another interesting observation about the Russian Caps, PTFE and PIO, is the tight tolerances in the ones I have purchased. No matter what the specs are. I bought a lot of 25 0.1uf teflons, some were 300v and some were 450v, measured on an accurate cap meter they were all within 1.5%. I used PIOs and teflons in my Hagerman CornetII, for the reasons you stated, it needed clarity in the mids and bass, they solved that problem. My Eros with Mundorfs in the RIAA, and output positions has no such problem, though I have to say that 4 .01uf silver/oils per side, (1 each for the .01s and 3 each for the .03s), got a little expensive even with a sale. Almost done with the quickie, I put my Khozmo stepper that I scavenged from the Cavalli Bijou in, cost more than the kit! Why not?
Shawn
Post by: Grainger49 on April 21, 2012, 08:21:06 AM
I'll post a picture showing the relative sizes.
Stock Solen 01.0uF@630V are the tiny black ones
Mundorf S/G/O@800VAC, 1200VDC are the larger black ones
KK Teflons FT-3 0.22uF@600V are the large silver ones
KK PIO K75-24 2.2uF@500V are the green bodied ones
As posted above I tried both one and 2 KK Teflons per channel, liked one better.  The KK PIOs were already set up, wired in parallel, to go into my second set of Minimus 7s.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi244.photobucket.com%2Falbums%2Fgg7%2FGrainger49%2FFor%2520Posts%2520Private%2FIMG_08871.jpg&hash=cb31f465e8c9c47b471bc185d8ac0d088e4a6a55)
Post by: Grainger49 on April 22, 2012, 01:59:11 PM
Sadly the arrangement in the above picture is still there.  I have rotated through the 4 sets of caps and each is different and each sounds good.  The system needs to be warmed up for a good comparison.  Even the stock Solen has some nice images.
I still think the Mundorf S/G/O is the winner followed by the KK Teflon.
More listening tomorrow.
Post by: Paul Joppa on April 22, 2012, 03:04:10 PM
...  Even the stock Solen has some nice images.  ...
Heh heh, yeah the Solens can creep up on you. Some say they take as long as the teflons to sound their best; n any case the process (after the first 20 hours or so) is slow and undramatic.
Thanks for the careful, long-term reporting. We often say "...the difference is not subtle" but evaluating the difference can be a long slog, getting past first impressions of Different to later impressions of Better.
Post by: Noskipallwd on April 22, 2012, 08:15:26 PM
This might be better served in it's own thread, but I will ask anyway. What is the science behind the long burn-in for caps with Teflon dielectric?
Shawn
Post by: ALEXZ on April 23, 2012, 04:56:47 AM
Grainger,
Could you please describe your testing  environment (hardware /software) and procedures.  It
Post by: Grainger49 on April 23, 2012, 12:13:25 PM
Alex,
Let's start with my personal mantra (often posted in the Bottlehead threads).  Capacitors, wire and tubes are a matter of personal taste.  Capacitors are much like spicing.  Do you like habanero peppers, bell peppers or ancho peppers?  We each look for different things in our playback.
The #1 thing for me is soundstage followed by clear clean highs.  But the highs are where I have my hearing loss (isn't it always in the highs?).  Ask PJ who worked around jet engines!  We, he and I, know what loud is!
My system is in my signature, no reason to duplicate it here.  My room is 24' long and 14' wide.  The speakers are about 1/3 of the way into the room and my chair about 1/3 of the way from the back wall.  So a rule of thirds.  The speakers are well away from any wall.  I use a BA sub and fill in my hearing loss with super tweeters.  Software, the music I'm listening to is detailed in the posts (I think, isn't it?).
I have soldered a pair of wires on the terminals where each of the Solen caps were.  Those wires come out and I attach the capacitors with the jumpers.  Look at the picture in reply #10.  I know what I am listening to but I'm pretty experienced at listening.  I started this in the 60s.  I can only report what I hear, not what anyone else hears.
Going back this is what I have said about the KK PIO:
"...they are surprisingly good sounding.  Definitely better for me than the stock Solen."
"Comparing to the KK K75-24 that were playing the Solen is not as clear in the mids and highs."  Not that the highs were the best, just better and more detailed than the Solen.
If I have conveyed that the KK PIO are as good as the Mundorf, that is wrong.  The Mundorf caps sound the best.  But the PIO are not as bad as I had assumed they would be.  The stock Solen were run in for 2 or 3 weeks while I leisurely built the Eros.  And have remained in there till I started this thread.  So they were completely broken in, as were the KK Teflons.  I think the Teflons sit at second place.
I just went from KK Teflon to KK PIO.  The top end doesn't shimmer like the Teflon.  The midrange is warm and present.  It is kind of seductive.  The bass is good but now as well delineated as with more expensive caps.  But they are very "Tubey" sounding.  Like I say, seductive.
Have I answered all your questions?
Post by: ALEXZ on April 23, 2012, 12:59:43 PM
Thank you.  The reason why I asked about environment is the following, k75 cap is popular remedy to mitigate hardness of SS electronics and digital records. That is right in sync with your description of the "tubes" sound. Objective parameters  of  K75 is plainly awfull, this a 50hz capacitor by design. In my experience, Solen is much more accurately sounding capacitor.
Totally different story with the FT caps, great caps all around.. Well...except size.
Of course you are right it is all very subjective topics, but I guess the reference point is the sound of the live acoustic instrument, never mind how romantic and golden is the sound of the component, but if it makes cello sounds like it warped in a towel, than probably something's wrong. That was my impression from the k75 capacitors.  Btw, there are also number of reasonably (well...for audio) priced caps in the price range between solens and mundorfs s/g that could give great results, for example dynamicaps, mundorf ZN.
Post by: Paul Joppa on April 23, 2012, 03:15:51 PM
Shawn
When you find out, please let everyone else know!  :^)
Seriously, there are a few theories out there, none of which are plausible, and few of which are even testable in any reasonable way. "Reasonable" means without a huge $$$ grant, and with results while we are still around to see them.
My perception, of course!
Post by: ALEXZ on April 23, 2012, 03:23:34 PM
Paul,
Are there any explanations for caps break-in effect ( not teflon, but in general)? For some of them (mundorf s/g  for example)  magnitude of changes is not subtle at all, almost like a speakers.
Post by: Noskipallwd on April 23, 2012, 06:09:48 PM
Considering some of the 'research' that our government has awarded grants for maybe we should apply. Maybe if we tied it in to the research on this field mouse here in Colorado, they got 20 mil. for that.
Shawn
Post by: Grainger49 on May 02, 2012, 08:53:08 AM
   .  .  .    Heh heh, yeah the Solens can creep up on you. Some say they take as long as the teflons to sound their best; in any case the process (after the first 20 hours or so) is slow and undramatic.
The Solens got a long burn in.  I finished my ALL STOCK build this fall and I have just begun to tweak the Eros.  The Solens have had several hundred hours break in.
The Mundorf S/G/O went in permanently today.
Post by: Paul Joppa on May 02, 2012, 11:15:01 AM
Paul,
I hear the same thing with most capacitors, and it makes no difference whether I listen throughout the breakin process or not - I tried it and really hoped that might be the explanation but it's not. I have never found an explanation with either reliable facts to back it up, or enough physics to make it plausible. Fortunately my experience is as an engineer; if I know what works and it is repeatable, then I can design with it whether or not I understand what is going on.
Post by: debk on June 25, 2013, 11:58:00 PM
Sorry to resurrect an old post, but I have replaced the 1.0uf Mundorf silver/oil caps with  0.22uf V-cap TFTF.  The V-caps are fully broken in have come from an older project that I have cannibalized.
The first thing I notice is that the sound is much clearer, the 1.0uf Mundorf sounded somewhat "smeared" compared to V-caps.  Soundstage is somewhat more immersive and more realistic sounding. I notice no change in the bass extension with the lower value caps.  Overall much more pleasurable to listen to.
Don't know if this is do to the V-caps or the value change, probably some of both.  I know changed too many variables at once, the more scientific way would have been to use a 0.22uf Mundorf silver/oil first and then tried the V-caps, but I didn't have them to try.
The bottom line is that I am happy with the change and in the end that all that counts.
Deb
Post by: Grainger49 on June 26, 2013, 01:49:09 PM
Amen Deb!  That is all that counts.  Checking I have a PM from PB saying a 400V cap is fine.  The V-Cap comes in 300V and 600V.  Hmmm, the difference is about $28.  Does an official Bottlehead want to chime in on saving $56 a pair?
I could go for either, but being the avowed cheapskate that I am I would like to save the bucks.  I could get a 1.75l bottle of Woodford reserve for that savings.
Post by: Paul Birkeland on June 26, 2013, 03:07:34 PM
I wouldn't be bothered by a 300V cap in the Eros.  An unloaded B+ rail in that power supply is going to creep up there a bit, but we have the CCS of the 6DJ8 feeding a plate load from plate to ground, so there is some built in voltage protection there that should take care of you.
Post by: Grainger49 on June 26, 2013, 11:57:52 PM
Thank you Paul!
Deb,
I was wondering about the 0.22uF value, then remembered that I put in one 0.22uF KK Teflon and it sounded more than fine on the bottom end (with Triangle Zerius and sub back then).  Into the 100k FP 2 pot that calculates as a -3dB point of 7.23 Hz and essentially flat at 72.3 Hz.  That is a faint roll off between the two frequencies.
I think Paul pushed me into it, I'll go for the high priced spread here.  And break them in on my Eagle 2C (sold the GainClone) downstairs for a month.
Post by: debk on June 27, 2013, 02:19:26 AM
Grainger
I used the 0.22uf value after reading some of your previous post in this thread.  I think it sonds better than the 1uf I had in there already.  I probably would have gone for a 0.47uf but I already had the the 0.22uf
Deb
Post by: Grainger49 on June 28, 2013, 12:16:37 AM
Glad to be some help.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi244.photobucket.com%2Falbums%2Fgg7%2FGrainger49%2FSmiles%2FTipHat.gif&hash=e6ef7f0d5488d01ff7ef90294fc834dbd255538c)
Post by: Atom Shop on August 27, 2013, 05:04:20 PM
Your input on caps, Grainger49, is more than "help"!
BUT, if you those of you out there wanna make your head swim (or explode! :o) as to what might be other options in the cap rolling department, check these out.
http://www.humblehomemadehifi.com/Cap.html
http://www.v-cap.com/pdf-files/21capacitorshootout.pdf
http://www.enjoythemusic.com/diy/0708/capacitor1.htm - parts 1, 2 and 3
https://www.head-fi.org/t/284863/orgy-of-capacitors-the-cap-thread - very length-y
http://diy.ecpaudio.com/p/some-notes-on-coupling-capacitors.html
http://tech.juaneda.com/en/articles/electrolyticcapacitors.html - electrolytics
http://www.laventure.net/tourist/caps.htm
Even though some of this stuff may be appear dated the results make for some interesting debate, discussion, arguments, etc. My personal experience with some of the Russian goodies has been very rewarding.
Post by: Grainger49 on August 31, 2013, 08:13:14 AM
I think the key difference here is that I am not paid to make these comparisons.  I have to buy the capacitors myself, mostly without a personal income.
I would really be interested to see the total cost of the capacitors in one of these reviews.
Post by: Grainger49 on September 07, 2013, 05:05:10 AM
A Care Package arrived this week.  I had ordered two pair of caps two months ago.  I forgot, completely forgot.
I am now burning in two TFTF V-Caps, they are due off on the 22nd.  Then into the Eros!
Post by: corndog71 on September 07, 2013, 05:59:46 AM
You're in the deep water with the big kids now. :)
Post by: debk on September 07, 2013, 06:02:56 AM
Grainger
What value capacitor did you go with?
Deb
Post by: Grainger49 on September 07, 2013, 07:32:36 AM
Rob,
Well, I was making money then and it was a weak moment.
Deb,
0.47uF.  That is the design value for the last stage; same as the Seduction.  The values delivered, there have been two different values I am aware of, are a upgraded film Solen caps.  Upgrade sonically from the brown metalized Polypropylene film caps delivered in the Seduction.
Post by: Grainger49 on September 13, 2013, 10:10:33 AM
I check the connections to the TFTF caps every day.  The two cats sleep in this room and they are awful about messing things up.  So far, so good.
Post by: 2wo on September 13, 2013, 06:43:45 PM
I should have warned you about the catnip impregnated caps...John
Post by: mcandmar on December 16, 2013, 03:45:24 PM
Bump.   ....you need to finish the story :)
Post by: Grainger49 on December 27, 2013, 12:13:34 PM
Sadly... I have not done a comparison yet.  The Caps are burned in and ready.  But I have many other things, house/personal, that have come before my listening.
Maybe soon.  I'm sick as a dog and not ready to do anything physical.
Post by: johnsonad on December 27, 2013, 01:17:20 PM
I put the 0.47uF TFTF in my Eros (tape) and am very happy with the results.
Post by: mcandmar on December 29, 2013, 11:17:14 AM
Well keep us posted when you do get to them ;)
..and get well soon!
Post by: johnsonad on January 04, 2014, 02:23:03 PM
I move the V Cap Teflon's from my Eros tape to the Tube Phono replacing a pair of Auricaps. The difference was immediate and I'm kicking myself for not doing it earlier. The Auricaps are great but I'm a detail guy and the Teflon's seem to get  a little more out of what's already there.
Post by: Dnorris on March 21, 2014, 12:08:12 PM
I'm starting a new Eros build (stock first, of course), but have a pair of .47uf audio grade film capacitors that I want to try as well. To clarify, it looks like the design value for the output stage caps is .47uf as per Grainger's post, the parts checklist & schematic show 1.0uf and the included kit caps are 1.5uf. Am I correct in assuming the .47uf would work fine, just changing the bass rolloff point somewhat? Thanks in advance.
Post by: Dnorris on March 21, 2014, 12:17:14 PM
Oops, Sorry, forgot to add my name to my initial post.
Dale Norris, located in the Kansas City area. Built a Crack + Speedball with some tube rolling last year. Very happy with that indeed, spectacular sound with HD650.
Post by: Paul Birkeland on March 21, 2014, 12:45:10 PM
Yes, your statement about the low frequency performance is correct.
At the time that we put out the Eros, we had the 1.0uF Solen capacitor in our inventory for the SEX amp of that era.  When selecting the coupling cap for the Eros, we simply used the 1.0uF Solen because it was already in the inventory and it is a nice sounding cap.
Currently, the SEX parafeed cap is 1.5uF, so that ships with the Eros as well.
Post by: Paul Joppa on March 22, 2014, 06:40:05 AM
To add a bit here - the output stage of Eros is the same as Seduction (now Reduction). The original Seduction had a 0.47uF cap, which could work with load as low as 15Kohms, but with a trace of deep bass loss, -3dB at 22.5Hz. With Eros, we wanted an upgrade in performance and parts, and the 1.0uF Solen seemed appropriate.
Post by: Natural Sound on March 22, 2014, 07:22:32 AM
Hmmm... Good to know. I have a .47uF in my Seduction and it sounds real nice. Especially with my new Ortofon Blue cart. But I do have a pair of 1.0uF Solen capacitors that were removed from my S.E.X. 2.0 when I installed the MQ iron upgrade. I might just swap those into my Seduction for experimentation purposes.
Post by: Hank Murrow on March 22, 2014, 08:46:51 AM
The BH Customs "Eros" that PB built for me has 1uf TFTF V-caps at the output and the bass has plenty of extension and timbre. The bass drum whacks on the Holst Wind Band Suites with Frederick Fennel sound plenty deep and tactile, rattling a couple of hanging prints when listening quite loud. I have never tried swapping caps though, so cannot give a comparison____ it just sounds great!
Hank in Eugene
Post by: JamieMcC on March 22, 2014, 09:41:49 AM
Hank that is super the two Paul's really look to have cooked you up a beauty and something that must give a high level of pride in ownership as well as beautiful sounding music.
Jamie
Post by: Hank Murrow on March 23, 2014, 05:30:00 PM
I was very lucky that Dan introduced me to Paul Birkeland at the Vancouver VSAC. He also built my Soul Sister/Kugelis linestage, a fine stereo 2A3 amp, and a Custom Crack with many trick features including Submissive volume controls and a special PS. It sounds quite wonderful with my Cardas-cabled Senn 600's, reaching deeper into the low bass than my speaker system. I sometimes listen to my headphones while using my MacBook Pro and it is delightful to work this way. The other pieces also use V-Caps in all signal circuits.
Cheers, Hank
Post by: JamieMcC on March 25, 2014, 12:47:20 PM
Hi Hank, the Teflon capacitors are rather addictive aren't they. I was really surprised recently after taking some out of my Cracks circuit at just how plasticky and course my film caps sounded without them on  bypass duty. Prior to their fitting I was over the moon with the improvement the films gave over the stock electrolytes as well. The new ones are still in the burn in phase but already are sounding very delicious.
Cheers, Jamie
Post by: Sugar Man on May 10, 2016, 05:49:30 AM
Is there a consensus on what the ideal cap size would be for the Eros? My stock Solen's are 1.5uF and the bass is great.  One can obviously save money on 0.47uF boutique capacitors, but I don't want to weaken the bottom end.  Mundorf has a 0.47uF, 0.68uF, 1uF and 1.5uF.  From browsing earlier comments here, I saw that Grainger and DebK were even using 0.22uF and seemed happy.  Input appreciated before I run amok at the capacitor candy store.
Post by: Paul Joppa on May 10, 2016, 06:03:15 AM
There are two criteria that I use. First, the cap must be large enough to pass bass into the power amp's input impedance. Second, it must be large enough that its impedance is lower than the output impedance of the preamp at 120Hz - the power supply hum frequency. The second reduces the chance of hum pickup from electric fields. The 0.47uF meets the second criterion, and also meets the first if the power amp input impedance is above 15K - though the amp is specified to drive 50K or more.
Post by: Sugar Man on May 10, 2016, 06:38:17 AM
Thanks PJ.  So, since my Stereomour II has a 50K input impedance, is it safe to say the 0.47uF's will git 'er done on both criteria and save me a little coin?  ;D
Post by: Paul Joppa on May 10, 2016, 09:55:30 AM
Absolutely!
Post by: Sugar Man on May 10, 2016, 10:32:16 AM
Awesome!  Since I also own a Seduction as well, I think I may start with a couple pairs of "relatively affordable" 0.47uF Mundorf MCap Supremes and Jupiter HT Beeswax for a shoot-out.  Then I might upgrade to the "relatively less affordable" Mundorf Silver Oils and/or Jupiter Copper Foils, and move the shoot-out winner over to the Seduction.
I recently had Warren Jarrett (Audio Note dealer here in SoCal) over for a listening session to audition a "gently used" Audio Note IQ3 MM cartridge.  He also brought along a fairly pricey Music First 632 phono preamp (solid state and it uses the Mundorf MCap Supremes) and it sounded really, really good in my system. I'm betting it's those boutique caps that were bringing the magic...
Post by: rockpassion on May 10, 2016, 03:03:34 PM
Mike,
I used  a pair of .22uf 600v Russian FT-3 Teflon capacitors.  I found the differences were mainly in the soundstage which became much more precise.   Also, the mids and highs are just outstanding and extremely musical.  I cannot tell a difference in bass response, the bass is very tight and deep enough for me.
I did not compare these caps to any other caps other than the ones that came with the kit.  But I will say the difference is very noticeable and I am extremely happy with the results.
Good luck.
Richard
