Bottlehead Kits => Crack => Topic started by: Nick Tam on October 14, 2012, 04:00:37 AM
Title: Rolling 6SN7s
Post by: Nick Tam on October 14, 2012, 04:00:37 AM
Okay so I've been running through the forums and have not been able to come to a straight conclusive answer as to if the 6SN7 is a direct drop in for the 12AU7 with adapter, so I just want to be sure that I don't kill the precious internals.
So from what I know, it IS a drop in replacement as long as I use a 9 to 8 pin adapter that has the bias set and rewired pin layouts for the 6SN7?
Also is it possible to run the ECC32/33 tube variants?
I'm running the Speedball so I'm just stuck at the voltage issue, someone clarify, thanks.
Also, I'm if anyone are able to give their impressions as to how the 6SN7's family sound characteristics compared to say the 12AU7 and 12BH7 and E80CC tubes would be great. Ever since getting my Crack I've only ever rolled in a RCA 12BH7A Foil D and a Tungsram E80CC, was wondering if the 6SN7 does any better in the soundstage and "spaciousness" department.
Thanks~
Title: Re: Rolling 6SN7s
Post by: Paul Birkeland on October 14, 2012, 07:29:50 AM
Yes, the 6SN7 will function identically in the circuit.  (The adapter just reroutes the pins, no other adjustments are made)
Post by: Paul Joppa on October 14, 2012, 04:52:52 PM
To clarify, the only significant difference is that the 6SN7 needs twice the heater current - which is no problem with the Crack, it has plenty to spare.
Post by: Nick Tam on October 15, 2012, 01:37:12 AM
Does this apply to the 6CG7/6FQ7 as well? Thanks
And if anybody knows, if it is safe to use the ECC32/CV181
Post by: Lar on October 15, 2012, 06:55:36 AM
I have used the CV181, but was not impressed with there sound.
Post by: Grainger49 on October 15, 2012, 07:00:13 AM
The 6CG7/6FQ7 is not a direct sub for the 12AU7.  It might work.  I have used a 12AX7 in the socket for a 6DJ8 and it worked, not well but made sound.  Those are not direct substitutes either.
Post by: Paul Birkeland on October 15, 2012, 10:16:54 AM
The 6CG7/FQ7 works if you rewire the heaters.
Post by: karl on October 21, 2012, 02:03:55 PM
Where can I find the adaptor?
Regards,
Post by: Paul Birkeland on October 21, 2012, 03:50:44 PM
http://www.ebay.com/itm/Two-adapters-for-12AU7-ECC82-6CG7-TUBES-amplifier-/260716251584?pt=Vintage_Electronics_R2&hash=item3cb3e649c0 (http://www.ebay.com/itm/Two-adapters-for-12AU7-ECC82-6CG7-TUBES-amplifier-/260716251584?pt=Vintage_Electronics_R2&hash=item3cb3e649c0)
I'm not affiliated with the seller, and if you're going from a 12AU7 to a 6CG7, the adapter would connect pins 4/5 to 4 and pin 9 to 5, going from a 6CG7 to a 12AU7, the adapter would connect pin 4 to pins 4 and 5, and pin 5 to pin 9.  Consequently, one adapter wouldn't go both ways, so I'd contact the seller before buying!
Post by: Lar on October 21, 2012, 07:38:14 PM
http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=320659633166&ssPageName=STRK:MEWAX:IT#ht_1080wt_793
Post by: Laudanum on October 22, 2012, 01:58:29 AM
Karl, I can confirm that the adaptors linked by Lars do work perfectly well for the 6SN7's.
Post by: Nick Tam on October 22, 2012, 04:07:17 PM
Hey guys, i dont want to pick up any flashy 6SN7s yet but how does the average 6SN7 sound fare against the best of 12AU7s, 12BH7s and E80CCs?
Post by: Laudanum on October 23, 2012, 02:33:52 AM
Dont know about the E80CC but for a very general description ... tubier (if thats a word).   That's how I would probably describe it but it's a generalization.   I prefer them, but some dont.    BTW, as far as non flashy 6SN7's go, I like the readily available Sylvania "T" plates just fine and they can be had for not much money.  These generally come as 6SN7 GTA and GTB.   Parallel T plates and angled T plates.   I think the Parallel T plates that I have I may prefer a little bit over the others but I wouldnt swear on it.  I think it is some (not all) of the GTA's with the parallel plates.   Many affordable old production 6SN7's to try.  I have a few of the VT 231's which are pretty well regarded, usually in the top 5 lists.  They are better but I dont think they throw the regular old GTA's and GTB's under the bus.   Google "best 6SN7 tubes"  and you will pull up a good deal of info and reviews.
Post by: Nick Tam on November 04, 2012, 09:31:39 PM
Hi guys. I ordered from that seller and they made the simplest messup and sent me a 6CG7>6sn7 converter instead. Should I just send the package back? it's a complete pain in the arse that they messed up and it took a whole week to deliver, even for a local delivery!
From what I understand, all I have to do is ground the 9 pin connection within the Crack if I were to use a 6CG7? Or I don't have to at all since the 9th pin doesn't go anywhere in a 6SN7 tube?
Post by: Grainger49 on November 05, 2012, 02:14:02 AM
I would ask the seller to pay return postage for sending the wrong adapter.  Contact him through ebay so there is a record of the screw up within ebay.
Post by: Laudanum on November 05, 2012, 02:20:22 AM
Nick ... Supposedly, most 6CG7's have an internal shield.  6FQ7 does not.   I have a few of these tubes and I believe that all of mine are labeled as "6CG7/6FQ7", none are shielded.   Also read that supposedly they all sound the same.
Anyway ... IF the tube is not shielded the quick and dirty wiring option is to cut the existing connection between pins 4 and 5 on the 12AU7 9 pin socket and then jumper over from pin 9 to whichever pin, 4 or 5 which is no longer connected to heater voltage.   If you have a shielded 6CG7, ground pin 9, seperate pins 4 and 5 and the connection from heater supply that was going to pin 9 (black wire) goes to the now electrically unconnected pin (4 or 5).   In other words,  on the 6CG7 and 6FQ7, pins 4 and 5 get the heater connection and pin 9 is open if the particular tube has no shield, or grounded if it does.    Safest bet is to ground pin 9 which allows for all 6FQ7's and both shielded or unshielded 6CG7's.
The quick and dirty option makes it easier to go back to 12AU7's or subs with same pinouts if you just want to try an unshielded 6CG7/6FQ7.
Post by: Nick Tam on November 05, 2012, 03:35:33 AM
I don't have a single 6CG7... the point I was making was that I was sent a wrong adapter from the seller for the 6CG7>6SN7 instead of the 12AU7>6SN7 one and was wondering if I could just use this as a 12AU7 adapter since the 6SN7 doesn't have that 9 pin, the 12AU7 socket to 6CG7 adapter basically has no connection and is technically free floating.
I'm just impatient to rolling in the 6SN7s I've ordered and I don't have the correct adapter.
12AU7 socket > 6CG7 adapter to 6SN7 pinouts > 6SN7 tube
Seller just said he'll send out the correct adapter and I don't have to return the old one... no questions asked. Although it's probably because he's just going to overlook the loss since the actual adapter was merely 5 dollars in value plus that 2 dollars shipping... basically breakeven since I bought the adapter for 15.5USD with shipping. What a nice seller...
Post by: Laudanum on November 05, 2012, 09:34:12 AM
Sorry Nick, thought you wanted to try a 6CG7 while waiting on a new adapter.
Post by: lextek on November 17, 2012, 08:11:05 AM
I picked up one of the Ebay adapters.  I had some nice 6SN7s from a previous amp hanging around.  Nice to have some more options to stick in your Crack.  Yes the 6SN7s sound very, good.
Post by: Nick Tam on November 17, 2012, 09:24:59 PM
They are indeed. Now I don't want to go back to the 12BH7/E80CCs I was using. They do music justice. They don't have the technicalities of the good E80CCs but that vintage sound that's just superior to the musicality of the 12BH7/12AU7s.
Post by: Natural Sound on November 25, 2012, 10:28:28 AM
I set up my crack amp to use 6SN7's from the beginning. Started by punching the front hole allowing me to install a second octal socket. From there all I had to do is make the necessary wiring changes during assembly. I really love the way it sounds. But I couldn't help wondering what the circuit sounded like with a 12AU7 up front. Basically I went the opposite way and bought an adaptor that converted the 6SN7 to a 12AU7. After some seriously critical tube rolling sessions I decided to stay with the 6SN7. Both tubes sounded really good. The 12AU7 actually did a better job at what I would call "micro detail." As good as that sounds there is a downside to having such good detail. That is to say that the 12AU7 really revealed all the nasties in poorly recorded material or poor analog to digital transfers. The 6SN7 is a lot more forgiving when listening to less than optimal source material.
Anyway, that's my 2 cents. As they say, "your mileage may vary." There are a lot of variables to consider. So have fun experimenting and set your amp up the way YOU like it.
Post by: Nick Tam on November 25, 2012, 04:24:51 PM
Yep they are forgiving. They also sound far more vintage than the 12BH7 or E80CC which I love for microdetail. They all have their pros and cons
Post by: adamct on January 14, 2013, 04:59:06 PM
 Question: I have a 6SN7 (tube) to 6DE7 (socket) adapter from my Woo Audio WA6. Can I use that adapter to run 6SN7s with my Crack+Speedball with the stock sockets and wiring?
Any advice is greatly appreciated!
Best regards,
Adam
