General Category => General Discussion => Topic started by: Doc B. on November 05, 2012, 10:06:03 AM
http://www.ebay.com/itm/MUSEUM-BROWN-BOVERI-T2001-1-TRIODE-TRANSMIT-VACUUM-TUBE-/310256909666?_trksid=p5713.m2062&_trkparms=aid%3D555001%26algo%3DPW.CURRENT%26ao%3D1%26asc%3D26%26meid%3D3253227739029682344%26pid%3D100042%26prg%3D1010%26rk%3D6%26sd%3D120970503707%26 (http://www.ebay.com/itm/MUSEUM-BROWN-BOVERI-T2001-1-TRIODE-TRANSMIT-VACUUM-TUBE-/310256909666?_trksid=p5713.m2062&_trkparms=aid%3D555001%26algo%3DPW.CURRENT%26ao%3D1%26asc%3D26%26meid%3D3253227739029682344%26pid%3D100042%26prg%3D1010%26rk%3D6%26sd%3D120970503707%26)
Filament is 7.5V, 50A
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi.ebayimg.com%2Ft%2FMUSEUM-BROWN-BOVERI-T2001-1-TRIODE-TRANSMIT-VACUUM-TUBE-%2F10%2F%21B4hGibwBGk%7E%24%28KGrHqQOKjIEyOiF3Iy6BMqL8E7U%21g%7E%7E_3.JPG&hash=47bdc7c31ac7f07af7422eff6e47ebb6cd0b909c)
http://www.scottbecker.net/tube/sheets/120/t/T2000-1.pdf (http://www.scottbecker.net/tube/sheets/120/t/T2000-1.pdf)
looks like those pins could use some cleaning up? don
High power SET, anyone? Should get 300 watts or so before it needs forced air cooling. The 3kV power supply might make a bit of ozone though. And the 100-pound output transformer could be a problem as well.
You need TWO for stereo.
DHT, from ABB. Hmmmm. This makes the 6C33C-B look like a tinker toy.
Looks like something from 'Lost in Space'!
Isnt that what the Russian "NASA" was using to transmit "please come, we have good vodka" into outer space in hopes to communicate with aliens?
