Bottlehead Kits => Crack => Topic started by: moviedave on April 16, 2013, 09:40:50 AM
Title: quick LED question
Post by: moviedave on April 16, 2013, 09:40:50 AM
Which small PC board on the speedball is connected to the LED going from the center pin to A3?
Title: Re: quick LED question
Post by: Paul Birkeland on April 16, 2013, 04:25:00 PM
Neither.
Post by: moviedave on April 16, 2013, 05:12:20 PM
The reason I asked is that is I installed the speedball and the LED connected to A8 didn't light up.  I unsoldered the small PCB boards and checked my work, and everything looked fine.  I put them back but swapped the which sides I soldered the boards onto.  After doing that, the LED on A3 didn't light up.  I will keep working.
Post by: Paul Birkeland on April 16, 2013, 05:23:16 PM
Always start with measuring voltages, the LED on A8 is indeed related to one of the smaller green PC boards.  Measuring the voltages at terminals 1, 2, 4, and 5 will tell us a lot about what's going on (and likely problems at terminals 6, 7, 9, and 10).
Post by: moviedave on April 18, 2013, 10:21:14 AM
Voltages were as follows
1. 85
2. 205
3. 0
4. 205
5. 0
6. 0
7. 124
8. 0
9. 94
10. 0
2 and 4 are a little on the high side, but the biggest issues are terminal 5 reading 0 and terminal 7 reading 124.
Post by: Paul Birkeland on April 18, 2013, 11:13:45 AM
You're not getting voltage out of one of the small green C4S boards, that is causing the rest of the problems.  Measure the metal patch on each MJE350.  When you find the one that is zero, reheat the solder joint on the center leg of that transistor.
Post by: moviedave on April 19, 2013, 10:07:05 AM
Are you sure that has to be the problem?  I did as you said, and found the thingy that had a zero voltage reading and resoldered the center leg.  It did not help.  Anything else that could be the source of the problem?
Post by: Paul Birkeland on April 19, 2013, 10:08:58 AM
Measure the voltage at the "I" solder pad on each small green board, they should be the same.
Also verify that the 2n2907's and 2n2222a's are in the correct places.
Post by: moviedave on April 19, 2013, 12:18:23 PM
The voltages are the same at the "I"'.  I will recheck my solder joints again.  I installed the speedball and had it working.  I later reverted it to stock to check the difference in how it sounded.  Deciding I liked it better with the speedball, I am putting it back.  I know everthing is where it should be on the board.  I just need to find out where the goof is.  Thanks for the help.
Post by: Paul Birkeland on April 19, 2013, 01:43:59 PM
Ah, OK, that is very helpful information.
You should be able to nail down that small green PC board.  Do note that a loose black wire on that board could cause the same problem.
Post by: moviedave on April 20, 2013, 06:46:08 PM
Solved that problem.  Re-soldered all my joints.  Now, I seem to have a new one.  Everything now has a reading, but a few are too high.
2. 201
4. 201
7. 123
9. 136
13. 201
15. 214
b2. 201
b3. 122
b5. 201
b6. 135
Any advice for this?  They seem to be higher in pairs.
Post by: Paul Birkeland on April 21, 2013, 07:33:16 AM
What are terminals 1 and 5 reading now?  These have a lot of control over how the rest fall into line.
Post by: moviedave on April 21, 2013, 08:02:31 AM
1. 83
5. 78
I didn't include them as they were well within the acceptable range, but what do I know.
Post by: Paul Birkeland on April 21, 2013, 08:57:32 AM
You're in operating range, I would go ahead and give her a listen.
Post by: moviedave on April 22, 2013, 01:52:49 AM
Only getting a hum from the left channel.  Where to go from here?
Post by: Paul Birkeland on April 22, 2013, 05:11:18 AM
Was the amplifier operating properly before the installation of the Speedball?
Post by: moviedave on April 22, 2013, 05:59:09 AM
yes it was
Post by: Paul Birkeland on April 22, 2013, 06:06:02 AM
Well, the good news is that the 12AU7 is operating properly, and the two small green PC boards are A-OK.
Moving on to the large green PC board, I'd give it a solid once over again to be sure you didn't miss any joints.  Do all 4 LED's light up equally brightly?
It's a little strange, because your 6080 is drawing some current, but not quite enough.  It's also odd that it is the same for both channels.  This makes me suspect the red wire from 2U going to the larger green PC board is not making sufficient contact, or the red jumper from B+ to B+.
Post by: moviedave on April 22, 2013, 06:25:03 AM
Actually, the hum is coming from the right channel along with the music.  The left is silent.  The LEDs are all bright and the 2U and B+ to B+ jumper are soldered well.
Post by: moviedave on April 22, 2013, 06:51:38 AM
The 2N2222A nearest the small PCB boards feels loose all of a sudden.  Could that be the culprit?
Post by: Paul Birkeland on April 22, 2013, 07:20:19 AM
It would seem unlikely to influence both channels, but it's worth a shot!
Post by: moviedave on April 22, 2013, 07:56:08 AM
Well, now I have both channels working!  But there is still a loud hum (now on both sides, of course).  The hum is the same volume no matter what the volume pot is at.  The sad thing is, I am really starting to enjoy soldering.  I just wish it wasn't was on something else at this point.
