Bottlehead Kits => Legacy Kit Products => Paramount => Topic started by: docbob52 on June 09, 2013, 09:20:22 AM
Title: Paramount voltage problems? All help appreciated
Post by: docbob52 on June 09, 2013, 09:20:22 AM
I was about to listen to the Paramounts but I noted several voltage discrepancies:
Terminal should be / Is
6: 0/ 75
10: 233/ 0
11: 164/ 231
12: 0/ 163 A amp and 126 B amp
13: 94/ 0 and this terminal in the manual has no connections so I think this is a misprint
Resistances were all ok except
9: 124k/ 292k A amp
Title: Re: Paramount voltage problems? All help appreciated
Post by: fullheadofnothing on June 09, 2013, 07:47:33 PM
There were some issues with the voltage measurements in the Paramount 1.1 manual. I've fixed them and revamped the tests for the manual. There is a sticky post at the top of this forum that goes over the new measurements. I seem to recall terminal ten was one of the more troublesome. Try those new tests and post back if you still have discrepancies.
Post by: docbob52 on June 10, 2013, 01:24:40 PM
Josh,
That takes care of terminal 10 being 0 as it was on my assessment.  I still have the following discrepancies that are greater 15%
6: 0/ 75
11: 164/ 231
12: 0/ 163 on the A amp and 126 on the B amp
13: 94/ 0
Resistances were all ok except:
9: 124k/ 292k on the  A amp, the B amp was normal.
All help appreciated.
