General Category => General Discussion => Topic started by: docbob52 on June 22, 2013, 05:52:55 AM
Title: Clear Coating the chassis plate on the BeePre
Post by: docbob52 on June 22, 2013, 05:52:55 AM
I love the swirled new chassis plate, so much I decided not to paint it.  I do want to clear coat it with a spray finish.  I have some clear Lacquer spray here.  Any better ideas for a clear coat on aluminum?
Title: Re: Clear Coating the chassis plate on the BeePre
Post by: Paul Birkeland on June 22, 2013, 06:25:11 AM
You can indeed clear coat aluminum, but I'd have a tough time figuring out what would be gained from doing so.
One potential option would be to have the plate clear anodized, which would harden up the brushed swirls, but it potentially would change the color of the material significantly.
If you do spray a clear lacquer over the plate, you could change the gloss level (good) and potentially protect from scratches (maybe not that useful), but at some point that coating may begin to flake off, and that can be really frustrating.
The best option for a clear coat, IMO, would be to have the plate powder coated.  This will go on thicker and adhere better than other products you could get at your local home improvement store (and you can have the transformer covers coated at the same time).
Post by: Doc B. on June 22, 2013, 07:04:17 AM
Clear coat fills in the brush pattern because it is not very deep. The plate will lose some of the interesting changes in visual texture that you see as the light angle changes.
Post by: docbob52 on June 22, 2013, 11:44:57 AM
Thanks so much for the advise. I don't want to loose the interesting pattern so I will leave it unpainted.
Post by: Grainger49 on June 23, 2013, 01:05:03 AM
Just use some Windex on it to clean it from time to time.  This is what I do.  Let the tubes cool first, of course.
Post by: Armaegis on June 23, 2013, 09:14:28 AM
random thought: how about car wax?
Post by: ssssly on June 26, 2013, 01:48:54 AM
Brush on, oil based polyurethane won't fill in the recesses nearly as much and will allow them to be visible in the final product. It is not totally clear though. It will give it a bit of "patina". I however think it looks good that way.
Post by: Doc B. on June 26, 2013, 04:32:21 AM
That's a good idea. I'll take it one step further (thinner?) by suggesting spray lacquer. That might not fill in the brush pattern as much as other coatings. However I haven't tried it myself so I don't know for sure.
Post by: Lee Hankins on June 26, 2013, 04:35:57 AM
Just have your top plate clear or colored anodized, will not fill in the pattern.  Had a setup for years doing parts for boats and motorcycles.
Lee Hankins
Post by: Paul Birkeland on June 26, 2013, 04:52:52 AM
The anodizing won't fill the pattern, but I would wonder about what the pattern would look like when the gloss to matte color gradations were neutralized by the anodizing process.
Title: Gun oil?
Post by: RPMac on July 19, 2013, 04:34:52 AM
What would be the problems of using gun oil on the top plate?
Post by: 2wo on July 19, 2013, 04:36:38 PM
Dust...John
