General Category => General Discussion => Topic started by: earwaxxer on July 06, 2013, 12:58:55 PM
Title: Sound quality and air temperature....
Post by: earwaxxer on July 06, 2013, 12:58:55 PM
I figured, that I couldn't do much worse than Greg's lame tar thread, so, I'm sitting here listening to some old Chicago, very much enjoying it, and I says to myself, "self - Its time to start a thread - I'm suffering here, and I need a distraction". You may wonder, "suffering", why? Did the poor boy run out of his trusty medications? No, plenty of meds, beer, etc. The cause for my recent run in with physical and psychic discomfort comes from the sudden ceasing of said central air conditioning unit, without warning.
So, sitting here, as still as possible with fans on max, the temperature has slowly risen (inside) to almost 90 deg. My kit is very well heat sinked so at moderate volume there is nary a worry. Even the monstrous Emotiva at 500wpc is barely breaking a sweat. Of course the Q is cool as a cucumber.
Now on to the topic at hand. Is the sound 'better' due to the decreased air density OR is the psychological desire to "check out" from the physical to live in the 'mind'. And, yes there are, and have been over time, beer(s) involved in said variables, but no more than usual. Of course there may be other audiophile type variables that I have not considered (as ambient temperature approaches body temperature there is minimal phase shift due to temperature gradient frontal boundaries as displaced by the formula PV=nRT). Feel free to interject, but be prepared to present your white paper to the group. - Talk amongst yourself -
Title: Re: Sound quality and air temperature....
Post by: Mike B on July 06, 2013, 01:14:08 PM
Alcohol always makes music sound better.
Music always sounds better when your day is done.
And, in your case, it takes your mind off how miserably hot your room is - :)
Post by: mpeg2 on July 06, 2013, 01:20:57 PM
Theoretically, music should sound worse as temperature goes up (lower density means that speakers won't move the air as well). My AC has been out for a while (new system going in on Monday) - the main issue that I found with listening is that the fans get in the way of the music.
I also found it necessary to put a fan on my cable modem & router - both overheated and stopped functioning until I figured it out...
Hope your system gets fixed (the one that does the cooling)...
Post by: earwaxxer on July 06, 2013, 02:11:28 PM
Thanks for the kind thoughts! - I hadnt thought about the cable modem, wifi etc. I will ck. that. We will be getting new AC on Tuesday. - True - lower density at higher temperatures, sound needs air to propagate. All makes sense. My brain definitely does not work as good when I'm hot. At least thats my personal experience. Could be an additive effect with the booze.
Post by: azrockitman on July 06, 2013, 02:36:21 PM
I was going to offer up the comment that since your AC is out, your house is quieter, thus allowing you to hear subtle sounds that are missed when the AC fan is detracting from the pure music.  But with a desk fan(s) turned on, so much for my theory.   ;)
Stay cool.  I would definitely avoid listening to Canned Heat or Blood, Sweat and Tears.
Maybe you could listen to some:
Frigid Pink
ice T
or Creedence Clearwater Revival.
 8)
Post by: STURMJ on July 06, 2013, 04:52:11 PM
speed of sound should be about 30ft/sec faster at 90 ( vs. 60) .  But that whole less dense air at the speaker thing blows that theory away (assuming you belived the speed of sound thing making any difference)
must be the beer.
Post by: 2wo on July 06, 2013, 05:44:58 PM
Well, the air is thinner. On hot days Baseballs fly out of the park and planes are harder to get off the ground...John
Post by: Paul Birkeland on July 06, 2013, 07:17:07 PM
I have also heard anecdotally that a system's SPL will increase at lower elevations (greater air density).
Post by: 4krow on July 07, 2013, 07:25:03 AM
 You moron...if you would have used the foam I was talking about in the first place, your home would have stayed cooler longer, but NOooOO(John Belushi) you didn't do it, and now my friend, you will pay. Oh btw, your addditionally a moron for turning on all those unneccesary appliances...geeez.
Post by: earwaxxer on July 07, 2013, 07:40:28 AM
I knew Greg would have some "constructive" insight into the topic! I still think the foam thing is pretty lame... I mean, the smell has to be bad. It probably never goes away!
Post by: ironbut on July 07, 2013, 08:34:34 AM
Slightly off topic;
Any of you guys found a fan that's quieter than the run of the mill?
I have a window air conditioner in the living room but the room that I have my little project studio is in a side room that gets pretty hot. I use a fan to redirect some of the cool air into the studio and it works pretty well but the noise can be a bummer.
BTW, I don't want to spend a bunch of cash so no Dyson suggestions please.
Post by: earwaxxer on July 07, 2013, 09:02:14 AM
Vornado's are pretty quiet and move a lot of air..
Post by: 4krow on July 07, 2013, 10:28:22 AM
I had 'Vornado' insurance once.....but seriously, is that the one from Dyson? Seems that it would be absolutely quiet.
Post by: 2wo on July 07, 2013, 11:07:23 AM
How about ceiling fans, goog ones are pretty quite...John
Post by: Grainger49 on July 07, 2013, 11:40:43 AM
Yes, somehow Dyson got a patent on the air horn, been around for about 100 years.  The Dyson is both quiet and expensive.  Oh, BTW, it does have blades they are in the base.
Post by: 4krow on July 07, 2013, 02:03:41 PM
 I  KNUE IT!
Post by: earwaxxer on July 07, 2013, 02:08:37 PM
Vornado is a brand that I have found here and their in the big box stores. Costco has them off and on. I still have one from about 15yrs ago. It blows air on me when I'm sleeping. I'm dont really like fan noise like some people do.
Post by: Grainger49 on July 07, 2013, 02:46:04 PM
Greg,
They advertise it as bladeless. Like they manufacture the air.
Comment to Eric below:  "Dyson, the Bose of home appliances"
Post by: earwaxxer on July 07, 2013, 03:34:14 PM
Dyson is the biggest snake oil con artist their is. Its all high priced hype. A vacuum cleaner is a very simple device, but no, he has to have fancy schmancie high RPM motors etc, that dont pick up dirt better than any other average motor/fan set up.
Post by: Armaegis on July 07, 2013, 04:26:18 PM
Delirium from heat stroke will also improve musical appreciation, assuming you remember it.
I find a fan blowing the hot air out of a room generally works better, although a fan blowing inwards "feels" better with the breeze directly on you.
Post by: Chris on July 07, 2013, 07:42:25 PM
I would surmise temperatures as well as humidity level changes would have more of an effect on the body and mood affecting the ears sound processing abilities and thus the brains perceptions  than anything else....
Post by: earwaxxer on July 08, 2013, 04:04:53 AM
I think Chris may have the best answer yet...
Post by: Tickwomp on July 08, 2013, 04:09:08 AM
Maybe your stuff sounds better when the "air" is off because the compressors put a bunch of crap on your AC lines that degrade the sound?  IMO, nothing sounds good when you're sweating and sitting in a pool of your own juice:-(
Tick
Post by: earwaxxer on July 08, 2013, 04:13:51 AM
The Tick speaks the truth, but dont forget, Greg will tell you, "its a dry heat". You dont really sweat -  you just bake - like a frickin potato!
Post by: 4krow on July 08, 2013, 06:07:43 AM
 LOL yup he's right folks, it's a dry heat. And in wyoming it's a dry wind.
Post by: mpeg2 on July 08, 2013, 08:11:50 AM
There's hope - over here, the crew showed up at 8AM this morning, cold air blowing out of the vents at 2PM. Hope your install goes smoothly...
   Rich
Post by: Chris on July 08, 2013, 10:16:43 AM
Yeah, I am with Tick and was also going to add about the AC adding noise to the line... Probably a combo of all the things mentioned...
Post by: ironbut on July 08, 2013, 11:18:27 AM
Hey Guys,
Thanks for all the advice.
I'd read about the Vornado fans and I'll probably get one of those and give it a try.
I used to work in a lot of nice homes and a pretty nice alternative to central air are those ductless systems from folks like Mitsubishi.
When I replaced my old window unit, I wish I'd gone the extra mile and installed one of these.
Just like Tick said, when I fire up my system on a hot day, I keep a basting brush with me.
