Bottlehead Kits => Legacy Kit Products => Quickie => Topic started by: precd on December 28, 2013, 07:52:16 PM
Title: One 9 volt battery much lower reading
Post by: precd on December 28, 2013, 07:52:16 PM
One of my 9 volt batteries have a much lower reading than the other 3. 3/4 of a volt. It is the far left 9 volt if you are viewing the Quickie outputs at the bottom. All batteries are Duracell Gold and from the same lot. This is a good time for me to learn what the 9 volts do individually. Any ideas as to what may be causing this?
Title: Re: One 9 volt battery much lower reading
Post by: Zimmer64 on December 28, 2013, 09:18:10 PM
That just happens at times to me too. I guess this is normal variance in production quality. They do not all discharge exactly the same way.
Michael
Post by: Paul Birkeland on December 29, 2013, 08:00:08 AM
All four 9V batteries are wired in series, and they all see the same current drain.  Having one battery go down earlier/faster than the others is probably an indication of production variations within the batteries themselves.
Post by: STURMJ on December 29, 2013, 11:33:57 AM
individually the batteries all do the same thing.  They are all joined together to make the 36V for the tubes.
