Bottlehead Kits => Crack => Topic started by: JamieMcC on February 10, 2014, 11:41:11 PM
First the disclaimer I am new to diy the bhc is my first and only build so far, however its sparked an interest that I am enjoying and which my other half now refers to as my new hobby!
Moving on.
I have noticed several posts which touch on swapping the two led's used for biasing on the input tube for resistors in order to achieve more optimal operating parameters (plate loads, I think) for different input tubes like the e80cc and 12bh7.
While swapping the leds for resistors is straight forward enough and an inexpensive thing to try it is not something I would want to do on a regular basis. I was thinking more along the lines of something switchable with set bias which might be top plate operated while listening (if practical)to reference effects .
I have seen mention of "bias pots" but have a feeling this might not be the same thing.
Might this be a practical thing to try or more detrimental to the sound quality with the added componentry.
Thoughts, pointers, links for further reading or associated parts welcome.
Cheers
Jamie
It's totally doable.
If you have the Speedball, it's a little more plausible to use resistors instead of LED's, but it won't sound quite as good.
IIRC, going up in bias voltage a little bit from 1.5V for the 12BH7 will nudge the plate voltage back into the desirable range.
ok thanks Paul that's interesting, the implementation looks like something I could tackle with some thought and further reading on the subject. This would also help me to have a better understanding of what I am actually doing and I might just start learning a bit about how the amp works rather than just swapping out one part for another.
Looks like I have plenty to read up on for starter.
Jamie
Looks like I have plenty to read up on for starters.
Jamie
What bias voltage should those with 12BH7s be shooting for? Would series HLMP-6000s work or maybe another LED?
Also, when using resistors would you recommend a bypass cap? (and value?)
Something higher than 1.5V, but not by much. 1.7-1.8V ought to be enough.
I don't think the bypass cap is necessary if you're going to use resistors.
