Bottlehead Kits => Crack => Topic started by: Strikkflypilot on April 03, 2014, 11:58:17 AM
Title: Crack Finishing Question
Post by: Strikkflypilot on April 03, 2014, 11:58:17 AM
Hi.
This is my first post as I just picked up my Crack at the post office today. :)
I got a can of Hammerite spray for my Project and noticed after3-4 coats that I should have used a primer.
Lokesen, did You prime Yours?
(I nevertheless continued to a total of 10 coats with 2-3 minutes inbetween.
Should I worry the paint will comeoff?
Title: Re: Crack Finishing Question
Post by: STURMJ on April 03, 2014, 04:05:54 PM
I don't think primer is nessecary for this paint.
Post by: Natural Sound on April 03, 2014, 04:15:36 PM
As long as you got the top plate nice and clean you should be fine.
Post by: Paul Birkeland on April 03, 2014, 05:52:40 PM
I've never put primer under Hammerite.  (I believe it says not to on the can)
Start with clean aluminum, then spray a good coating right on the plate.
If you re-coat, it changes the look pretty significantly.
Post by: Strikkflypilot on April 03, 2014, 06:24:01 PM
Just what I wanted to hear:)
Post by: JamieMcC on April 03, 2014, 10:15:20 PM
It will take a few days for the paint to fully cure even properly put the plate somewhere nice and warm or out in the sun and you will be good to go.
Post by: Grainger49 on April 04, 2014, 12:24:07 AM
I put the top plate of my Eros (copper hammerite) in the oven set at 150F for an hour.  Then I aired the house out.
Don't tell my wife!
Post by: Strikkflypilot on April 04, 2014, 10:14:50 AM
Thanks for the advice.
Dont think baking in the oven would be much appreciated:)
I put it on top of the water heater, must be around 80-85 degrees F.
Looks fantastic but still slightly sticky to the touch. Will post Pic.
Post by: Strikkflypilot on April 05, 2014, 07:42:12 PM
Looking good so far. Had some blob on the bell, sanded and recoated.
Post by: JamieMcC on April 05, 2014, 09:12:28 PM
Looking at the pic inspired me.
It had me wondering if cutting up a old chess board might make a neat enclosure for a crack.
