Bottlehead Kits => BeePre => Topic started by: tiguan on April 18, 2014, 04:46:55 AM
Title: Shall it be a match with Gamut D200Mk3 power
Post by: tiguan on April 18, 2014, 04:46:55 AM
Hi All. After building Jensen 1071 Speakers from Troels Gravesen, Lampucera DAC, Le Pacific Phono Pre, I would like to add a tube pre to the chain and stop all investigations and listen just music (hopefully :) )
My power is Gamut D200 Mk3 which I love.
Type: solid-state single MOSFET stereo power
amplifier
Power output (per channel, continuous):
200W/8Ω, 400W/4Ω
Frequency response: 5Hz ~ 100kHz
THD: ‹ 0.05%
Noise level: › 100dBA below 100W/8Ω
Input impedance: 40kΩ balanced, 20kΩ RCA
Sensitivity: 0.77V, 1.55V, 3.1V, 3.9V (full power)
Speaker loads: down to 1.5Ω
Shall BeePre300B a good match with power? Thanks all in advance.
Title: Re: Shall it be a match with Gamut D200Mk3 power
Post by: Paul Birkeland on April 18, 2014, 05:03:51 AM
The BeePre will work well driving that amplifier.
I would start at the 1.5V sensitivity setting, then perhaps move to a less sensitive setting if necessary.
